Yikes. I looked at the post history, seems as if a media plugin overwrote all of your files.
If you haven't made any other writes to the pool, you might be able to forcibly rewind to an earlier transaction.
Step 0: Back up anything that's important to another device.
zpool status poolname
and pick a device by GPTID
zdb -ul /dev/gptid/some-gptid-of-a-pool-device
- scroll through the output, look for a transaction group ID that is before the date where things went off the rails (before October 15th)
Export your pool.
Try to import it read-only with the command below.
zpool import -c /data/zfs/zpool.cache -o readonly=on -T <txgid> yourpoolname
You might need the -f
(Force) option as well.
Look for your files.
