Isuress
- Oct 11, 2016
TL;DR - What HBA would you suggest for a HP DL320G6 that will be running FreeNAS 9.10, connected to x2 MSA60s, with x12 1TB drives (24 total), with room to expand to 2TB, 3TB, and 4TB drives in the future as well as adding potentially a 3rd and 4th MSA60?
I don't have that much experience when it comes to RAID/HBA cards.
These are the 4 cards that have been recommended to me by other members thus far:
* LSI Logic SAS9200-8E
* LSI MegaRAID SAS9266-4i
* LSI MegaRAID SAS9266-8i
* StorageWorks H221
Why would I choose 1 card over another?
What are the pros and cons of each card?
I'm going to be using the MSA60 with x12 drives. Initially starting with all 1TB drives, and then slowly upgrading them to 2TB and 3TB respectively. Potentially even 4TB considering I already have x4 DeskStar HGST 4TB connected directly via SATA ports on the DL320G6.
I have 2 MSA60s, 12 drives each, 24 drives in total. Plus x4 4TB drives that are connected to the DL320G6 backplane. 28 total.
I will likely be using SATA drives rather than SAS drives as this is a homelab storage solution. I've read that the MSA60 has a bottleneck with SATA (1.5Gb/s) drives over SAS (3Gb/s) but I've been told I can get passed that with the right HBA.
I would like to get as much performance out of the drives as possible.
Which of these cards would be able to handle potentially x28 HDDs, ranging from 1TB to 4TB, and have reasonable performance on the drives for read/write?
If there's another card that would fit the bill much better that isn't currently listed, what would you recommend?
ALSO, how would I go about hooking up these cards? The /r/homelab Discord has told me that one would be able to daisy chain the MSA60s together? Is this true? If I were to purchase a 3rd or 4th MSA60 in the future, would I be able to continue chaining them?
Here is a diagram describing the possible configurations
If I were to daisy chain them, could I potentially lose read/write performance? If so, I may avoid this method.
Regardless of the configuration, I will still need to purchase 2 more SFF-8088 cables.
I will also consider purchasing x2 of the suggested card if it would mean I would get maximum performance out of each MSA60 unit.
* StorageWorks H221
