Recommend UPC with a minimum 900va+
a.rivera
I have a rack-mounted FreeNAS server that has a serial port and USB options to connect a UPS. Do you have any recommendations on UPS that can be rack-mounted and easy to configure in FreeNAS?
SweetAndLow
Sweet'NASty
sua2200rm2u is a good unit and usually pretty cheap because business have thrown them out.
SweetAndLow
Sweet'NASty
Thanks for the feedback is the set up as easy as plugin and select from the drop-down?
That's what I did. I have the network card in mine
troybs1d
I just replied to another thread saying how I like the CyberPower line-up so below is a copy of that. Also most 2200VA UPS that are for 120V usually have a 20A plug but if you keep the load low in relation to what it can support using an adapter like how I mentioned below you'll be fine. I keep my UPS at say 30% or less under full load though they're mostly idling.
I'm a fan of the CyberPower OR1500LCDRT2U / OR2200LCDRT2U (you can get a Nema 5-20 to 5-15 adapter for like $15) as they have both USB & serial connectivity. If you happen to run/convert to VMWare ESXi they provide a premade VM that can gracefully shutdown the hypervisor server (thus your FreeNAS VM) that is web configurable. You can also control outlet groups through serial/USB too.
