I can't say why it would take a month, but I've purchased several things from the seller I linked above. They are very knowledgeable and responsive to messages. If you have a specific need/time crunch they might be able to help you out.Ok I might have found some Dell PERC H310 refurb in Europe, must now find how to flash them in IT mode...
Otherwise only solution is ebay and have to wait almost a month...
What backplane do you have? Might this be a bad cable?Is it normal that the disks only run with 1.5 Gb/s on this configuration or am I doing something wrong? I'm just curious if I'm loosing performance because something is connected or configured wrong.
It is a SAS-846EL1 Rev 1.1 backplane. I currently have two different cables connected. One that was delivered with the server (connected to pri_j0) and the one I just installed. (I took the second cable from an HP Proliant DL380 G7) The one that was delivered with the server looks a bit cheap. (it does not have a cable sleeve)What backplane do you have? Might this be a bad cable?
I've just replaced the first cable, but the drives are still at 1.5 Gb/s. Is there something else I could do?It is a SAS-846EL1 Rev 1.1 backplane. I currently have two different cables connected. One that was delivered with the server (connected to pri_j0) and the one I just installed. (I took the second cable from an HP Proliant DL380 G7) The one that was delivered with the server looks a bit cheap. (it does not have a cable sleeve)
I also have a second cable from the Proliant server. I will try to replace the cable that came with the server also and see if this helps.
Ok thanks for the hint. Sadly I now have a bigger problem. After I've replaced the first cable I switched back to the old cable. After that the pool was in degraded state and TrueNAS tried to resilver over night. During the resilvering I noticed that the drives where now running at 3 Gb/s, so maybe this value just increases when there is more activity in the Pool?So, you have a SAS1 expander backplane… It should support 3 Gb/s connections, but first-generation LSI hardware is not up to the same standard as later models. It may be just a simple bug that could have been fixed, but all the SAS1 and SAS2 stuff has been discontinued for a while.
You can try to update the expander firmware, maybe the latest one does have a fix.
If not, you might be able to upgrade the backplane with either a passive (-A model) backplane or a more recent expander backplane. Be sure to research which models will fit your specific chassis.
