Darren Yorston
- Apr 26, 2015
Recently I experienced a degraded array as a result of a dead disc. I had problems replacing it as the disc did not appear anymore so I could not select Replace. Thankfully I had all my material stored elsewhere. Unfortunately advice here was unsuccessfull so I took the step of starting from scratch with all new WD red disks.
Ever since I have had trouble installing FreeNAS. I have had the error 19 code however now I am getting a problem in the installer. I am able to select the disc I want to install to however the installer reports:
gpart: arg0 'ada0' : Invalid argument
It then stops.
I have tried installing to multiple drives and USB2.0 sticks and get the same message.
I am trying to install 9.3.1 and have verified the checksum.
Installation is occuring on a system which has previously run FreeNAS for the past 2 years.
It then stops.
