SOLVED Raspberry Pi Desktop VM Problem
Alpha-Inc.
Hello everybody,
I recently installed Raspberry Pi OS Desktop as a VM on my FreeNAS 11.2 System. After the Installation of the OS, I was stuck in the UEFI Shell (See #1).
Via the GUI i managed to boot the OS by selecting the grubx64.efi file from the disk but after I selected Debian I just get a blank screen (See #2).
So is this a bug in bhyve which has a workaround or is my CPU / System just not powerful enough to run the VM ? (I have a Intel Atom C3955 CPU with 128 Gigs of ECC RAM).
Not so much a question of power as architecture.
The Pi OS variant of debian is compiled for ARM 32 or 64 bit chips.
You are running an AMD 64 architecture, so can't run that OS as a result.
You might want to look into the DietPi project (https://dietpi.com/), which makes a variant available for AMD 64 architecture (under PC/VM in the downloads).
Alpha-Inc.
Okay I'l take a look at it, thanks.
But one question, if i might add this, the same ISO of Pi OS Desktop can be run in a VM on my Windows and macOS Machine perfectly fine. They also have x64-86 architecture, so why is it possible on there (Running VirtualBox)?
Depends on the hypervisor you're running as some can emulate other architectures.
I can find plenty of information suggesting that QEMU can do that, but I didn't find anything saying that VirtualBox has the capability... maybe it does.
Bhyve doesn't do anything fancy like that at this stage AFAIK.
Alpha-Inc.
Okay understood.
I tried to Use Debian (AMD64-Version) but I get the same blank screen as shown in Picture #2.
Via the Graphical Install I installed SSH so after I bypassed the EFI-Shell and the blank screen appears, I could ssh into my server so it is running but I don't have any picture. When manually installing Tightvnc via the SSH-Shell I only get a grey screen without anything. So maybe do I need a GPU for me to get a picture?
I can't say for sure as all my systems have one, but there are others in the forum who run in serial console mode, so maybe they can share their experiences.
