After about 18 months of trouble-free service, one of the drives in my FreeNAS 9.10 box died. Since the drive is still under warranty (last month), I immediately requested an advanced replacement from Seagate ($12.70).
However, after re-reading the conditions of the replacement agreement, I am having second thoughts... The agreement states that the returned drives may be "processed" in a country with privacy standards lesser that those of the US, i.e., unlike in the US, there are no guarantees that the drive will be correctly data-sanitized. While the terms stated for processing the drives in the US look pretty firm, this got me spooked.
So here's my Q:
I tried to read up on the Forum and the web to answer this, but do not understand enough of what I did find. My FreeNAS box holds about 1 TB of mostly family pictures and music, but there are also backups of financials, family documents, and such. Not exactly top-secret, but not public either.
Normally, I would render the returned drive unreadable by zeroing some strategic sectors. Alas, this particular drive does not spin-up (more specifically, spins up, clunks twice, and spins down for good) so this is not possible.
Should I worry about returning this drive? If so, maybe I should return the replacement and just buy a new one.
I'd greatly appreciate advice/opnion on this.
Tom.
Hardware:
SUPERMICRO MBD-X10SLL-F-O uATX Server Motherboard LGA 1150 DDR3 1600
CPU INTEL|CELERON G1840 2.8G 2M R
Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM ECC Unbuffered DDR3L 1600 (PC3L 12800) Server Memory Model CT2KIT102472BD160B
4 x Seagate NAS HDD ST2000VN000 2TB 64MB Cache SATA 6.0Gb/s Internal Hard Drive
iStarUSA BPN-DE340SS-BLACK 3 x 5.25" to 4 x 3.5" SAS / SATA 6.0 Gb/s Trayless Hot-Swap Cage
SeaSonic SSR-350ST 350W 80 PLUS BRONZE Certified Active PFC Power Supply
Status report:
Checking status of zfs pools:
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
FNZ2_pool 7.25T 814G 6.45T - 3% 10% 1.00x DEGRADED /mnt
freenas-boot 7.44G 2.16G 5.27G - - 29% 1.00x ONLINE -
pool: FNZ2_pool
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 0h50m with 0 errors on Sun Nov 12 00:50:55 2017
NAME STATE READ WRITE CKSUM
FNZ2_pool DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/6ae1cb76-2dce-11e6-a778-448a5bca7639 ONLINE 0 0 0
10224831524614460661 UNAVAIL 0 105 0 was /dev/gptid/6b84fd98-2dce-11e6-a778-448a5bca7639
gptid/6c1db5af-2dce-11e6-a778-448a5bca7639 ONLINE 0 0 0
gptid/6cbe7067-2dce-11e6-a778-448a5bca7639 ONLINE 0 0 0
errors: No known data errors
So here's my Q:
- What data can be gleaned off one drive taken out of a set? (ZFS RAIDZ2, 4 drives, one volume, no encryption)
Tom.
Hardware:
Status report:
pool: FNZ2_pool
state: DEGRADED
