SOLVED RAID1 Mirror detached and attach not possible
Hi everyone,
Tomorrow I see on my FreeBSD interface that my raid 1 is degraded because one disc is failed.
My mainboard a gigabyte j1900 support hot swap on Sata ports.
Then i change the failed drive (hot swapped) and i connect a new clean formatted disc without partitions.
The new clean disc will detect by system and I start an replace under volumes - it's resulted in an error.
Then I go to detach my raid1 without mark as clean new disk (without data loss or formatting)
Actually it's dismantled (originally constellation) and detached.
Now I can't mount my raid1 volume.
I get only errors:
- zpool Import RAID1: one or more devices is currently unavailable
State is:
RAID1 unavailable missing device
Mirror-0 faulted corrupted data
Both discs are online
Sry when I put something what maybe is wrong but I'm new in freenas.
What is the way to reattach my drive to get my files?
When I import my raid1 pool then I get only error that RAID1 not found.
Thanks for help
Rafael
rs225
This looks bad.
Since you have three hard drives that may contain the data, I suggest connecting only one disk, and attempt to import that way. Maybe one of the three will work by itself.
  1. Please do not use external image hosts. Upload the images to the forum (just copy/paste them into the message) and delete your old links, please.
  2. Please make an effort not to use images just to grab a console output. You're helping conserve bandwidth and storage space, that way.
hi,
@Ericloewe: Sry but i write on my smartphone and it was very terrible to upload. My computer was not accessible at this moment.
Generally Update:
Topic can closed i have fixed!
I take the second member disc and it was possible to import with "zpool import -a".
Now i Copy everthing from the "Degraded" online disc to my new RAID01.
Thx and Sry
Rafael
