bmcclure937
- Jul 13, 2012
I am in the process of building a new FreeNAS and have been researching the best storage option for my needs.
My old FreeNAS 0.7.x box is running a 4x1TB RAIDZ1 pool. I understand that RAIDZ1 is frowned upon with larger HDDs. It seems that the options that would fit my needs and also follow community recommendations on my new FreeNAS. These options are listed below:
What are the advantages of RAIDZ2 over RAID 1? It seems I can get similar storage capacity for the price by configuring a RAID1 with 2 x 5TB drives. If I used RAIDZ2 and have 4 drives then I will get roughly 4.8GB usable space with the drives I have listed above.
If I do choose RAID1 then I have further research that needs completed to learn more about adding drives to the pool down the road if I would like to expand storage, etc. My chassis will be a Lenovo TS140 so choosing the larger drives also allows to only take 2 of the drive bays and have room for expansion later.
I appreciate all of your thoughts and input on this topic. As stated, I intend to do more research just do not have the time right this instant.
Thank You!
- RAID 1 (ZFS mirror) with 2 x 5TB WD Red drives
- RAIDZ2 with 4 x 3TB WD Red drives
Thank You!
