Raid-Z2 Used Space 100%, after it lost connection via iSCSI.
Kodya
Hi there.
I create zpool in Z2 with mirroring.
i'm created zvol and configure it for iSCSI using.
I forget about disk space, and someday my zvol become Used Space 100%.... and my host's lost connection to iscsi zvol....
Because i'm using oracle vm the filesystem of zvol = ocfs2.. and if i try mount this filesystem, i get next error.
dmesg | tail
[6494461.852069] (mount.ocfs2,2272,0):ocfs2_mount_volume:1893 ERROR: status = -5
[6494461.852630] (mount.ocfs2,2272,19):ocfs2_write_block:93 ERROR: status = -5
[6494461.852844] (mount.ocfs2,2272,19):ocfs2_journal_toggle_dirty:929 ERROR: status = -5
[6494461.853165] (mount.ocfs2,2272,19):ocfs2_journal_shutdown:996 ERROR: status = -5
[6494461.853940] (mount.ocfs2,2272,19):ocfs2_write_block:93 ERROR: status = -5
[6494461.854135] (mount.ocfs2,2272,19):ocfs2_update_disk_slot:217 ERROR: status = -5
[6494461.854478] (mount.ocfs2,2272,19):ocfs2_put_slot:540 ERROR: status = -5
[6494465.862760] o2dlm: Leaving domain 0004FB00000500003E75264B18FBF4E0
[6494465.863126] ocfs2: Unmounting device (249,4) on (node 2)
[6494465.863133] (mount.ocfs2,2272,19):ocfs2_fill_super:1218 ERROR: status = -5
How i can mount it, and get data from this zvol?
Samuel Tai
Please describe your pool and hardware in detail, as per the Forum Rules.
Use a VM that can read that filesystem and mount the zvol to it as a device.
A TrueNAS host won't be able to mount that filesystem.
