captain_price
 - May 25, 2021
If you install the BackupPC Plugin, you can use this script to get the Admin UI working, using scgi:
Code:# Prepare the Apache config config=" LoadModule scgi_module libexec/apache24/mod_scgi.so SCGIMount /admin 127.0.0.1:10268 <Location /admin> AuthUserFile /usr/local/etc/backuppc/htpasswd AuthType basic AuthName "access" require valid-user </Location> " # Write the config to the Includes echo "$config" > /usr/local/etc/apache24/Includes/backuppc.conf # Installed the extra packages requirements pkg install -y ap24-mod_scgi p5-SCGI rsync-bpc # Enable the SCGI port, fix the image location, allow 'admin' user as an Admin sed -i .bak 's|^$Conf{SCGIServerPort}.*|$Conf{SCGIServerPort} = 10268;|g' /usr/local/etc/backuppc/config.pl sed -i .bak 's|^$Conf{CgiAdminUsers}.*|$Conf{CgiAdminUsers} = "*";|g' /usr/local/etc/backuppc/config.pl sed -i .bak 's|^$Conf{CgiImageDirURL}.*|\$Conf{CgiImageDirURL} = "";|g' /usr/local/etc/backuppc/config.pl # Create the htpasswd file htpasswd -b -c /usr/local/etc/backuppc/htpasswd admin password # Allow backuppc user to modify the config chown backuppc /usr/local/etc/backuppc # Restart services to implement chnages service backuppc restart service apache24 restart
Hi, so sorry to re-open this thread again. When i try to access http://ip.of.the.jail/admin or http://ip.of.the.jail/bpc, i just get a message saying "The requested URL was not found on this server". When I just type the IP, I get a message saying "it works!". I have been googling for hours how to fix this and came across your comment, but i'm not sure how to use scgi to work. If you or anyone could clarify I would be super grateful!
