Quick question about drive noise
jnyl42
I just set up my first NAS with some hardware I had lying around and 6x 3TB WD Reds...
Is it normal for the drives to make "drive noise" in pulses rather than a consistent stream like they would in a regular desktop configuration? Or is it bottlenecking on my limited (8gb) RAM? The best way I can describe it is it sounds like someone eating crunchy breakfast cereal.
Thanks!
enemy85
Are u sure u don't have a faulty drive?
jnyl42
Pretty sure. It's not a "bad" sound... just regular old disk noise, only in bursts rather than a stream. I ran WD Lifeguard on all the drives when I got them and they all checked out fine.
Here is a sound sample... this is with the case open and the mic right next to the drives:
I also should have mentioned this is all during writes.
rs225
If you are using ZFS, yes, it is pretty normal that the writes happen in bursts. As for the sounds ..?
