PhilD13
- Sep 18, 2020
I am using the same version Multi-report script on two different machines and the emailed output from the two machines are very different in info provided and in how the email is formatted even though they are the same version of script and sent to the same email address. I compared the scripts and the spencer scripts between the two servers with notepad++ compare and other than different server names and minor path name differences everything setup and script wise is the same so I would think the email should look virtually the same as far as layout.
The major differences in machines would be one is a lot newer version of SuperMicro server, and the version of Scale that is being used on the two servers is different. Both machines have spinning rust as the majority of drives so both emailed reports should be showing that table section of the report.
Older machine running Scale 23.10.1 and Multi-Report v2.5
Newer machine running Scale 22.12.4.2 and Multi-Report v2.5
Best I can tell this is not affecting anything, but I am curious if someone knows why the output would be so different between the two.
Multi-Report v2.5 dtd:2023-11-26 (TrueNAS Scale 23.10.1)
Report Run 20-Jan-2024 @ 00:00:01
Execution Time: 0 Minutes : 8 Seconds
This is the older model of Supermicro machine with the script version 2.5 and Scale version of (23.10.1). The email sent only shows the *ZPool/ZFS Status Report Summary table then displays the Multi-Report Text Section without ever showing the Spinning Rust Summary Report table section.
Multi-Report v2.5 dtd:2023-11-26 (TrueNAS Scale 22.12.4.2)
Report Run 20-Jan-2024 @ 00:00:03
Execution Time: 56 Seconds
This is the newer Supermicro server (one listed in my signature) that is running the older Bluefin Scale (22.12.4.2) but using the same version 2.5 of the script. This machine shows the *ZPool/ZFS Status Report Summary table then shows the Spinning Rust Summary Report table, then a SSD Summary Report, before displaying the Multi-Report Text Section.
