question about zpool and dataset size delta
denut
hello
i have a question about the size my pool (1.9TiB) and my dataset only 1.4TiB
why this difference of 192GiB
tank's
depasseg
FreeNAS Replicant
Parity and possibly snapshots.
denut
snapshot i thick no
but parity maybe but i dont understand something
i have 16x149GiB driver in raidz3 this give me a 2.38TiB pool minus 3 drives total 1.9Tib size of my volume all is ok
i create a dataset and then the size is now only 1.7Tib
where are this 200GiB
my question was incomplete, thank's for you fast reply :)
depasseg
FreeNAS Replicant
the first line is the raw size
the second line is the size after parity and file system structure.
Are you sure your disks are 149GiB, or are they 149GB? There is a ~10% difference between those terms.
depasseg
FreeNAS Replicant
denut
thank's
i enter 0.160GB
result in picture 1.892 TiB but I have 1.7
denut
maybe i have a idea
i'm not using only 160GB drives but a mix because I don't have all my new drives (i have considerate all drives like the smaller)
there is some 160GB some 250GB, 500GB, 1TB, 1.5TB, and 2TB
is it possible due to drives with 4k sectors and other not ?
denut
at end all drives will be 2TB
and my problem is to be sure at end with my all 2TB drives i will not lost exponentially the difference i see at this point
Bidule0hm
Server Electronics Sorcerer
denut
ok tank's i read this tomorrow or after tomorrow , too tired tonight and i give you feedback :)
denut
and if i need recreate the pool what is the best ashift (or and) record size value for a raidz3 16 hdd (video and VM storage)
tank's
denut
and is it a command to check what drive is native a 4k or 512b ?
EDIT:
i found a command : fdisk -itv /dev/da12 answers no at the first question and report the sector size
all of my drive show 512b ...
after i found a list of 4096b drives but all have physically 4096b but logically 512b
https://wiki.archlinux.org/index.php/Advanced_Format
then if most of drives are logically 512b why freenas set a default ashift to 12 and not 9 ?
is my controller and or back plane not 4096b compatible ,Supermicro BPN-SAS-836EL1 16 Hotswap, LSI sas 9211-8i 6 Gbits/s 8 ports sas ?
many question !!!!
Bidule0hm
Actually there's no real harm (no lost space, maybe a little bit of perfs loss) to use 4 kB blocks on 512 B sectors drives.
It's the physical value that matters here. The logical 512 B is only for compatibility.
What are the models of your drives?
denut
A lot of different drives some wd20ears wd20earx segate constellation 2tb and smaller 500gb Samsung and western digital
Total 16 drives in raidz3
At beginning I was working with a 160gb for the smallest drive and the delta was 200gb
Now the smallest is 320gb and the delta have grow to 800gb
I need to understand why because after changing my last drive to a 2tb the delta will be dramatically enormous and if I need to recreate the pool I must now how before I have to many data inside....
denut
next test :
i have recreated my pool on vmware workstation with the same drive size the pool was set automatically to ashift=9 and there is no delta
my pool with ashift= 12 400Gb delta (on the total pool) and 800GB on free space .....
then i'm will try to recreate my pool
if any one have solution to change this value without recreate i need it :)
Bidule0hm
At least the WD20EARX should be a 4 kB sector drive.
Yep, already told you that in the previous post.
denut
can you give me the command to create the pool with ashift=9 and mixed drives size
because all i try don't work
"zpool create -f -O ashift=9 -m /mnt/v16d v16d raidz3 ada1 ada2 ada3 ada4 ada5 ada6 ada7 ada8 ada9 ada10 ada11 ada12 ada13 ada14 ada15 ada16"
and by simple creation the pool is not visible in the web interface...
tank's
