djoole
- Oct 3, 2011
[solved] Putty settings to have delete key working
I'm using putty to SSH to the FreeNAS 8.
Problem is the DEL key is acting like the BACKSPACE key (it eats caracters at the left of the cursor).
Is there a way to configure putty so that DEL key works fine?
I never had the problem on linux systems.
Thanks
Thanks
