I'm trying to make putty transfer properly Home, End, Backspace and Delete keys. although web shell is set for "xterm", setting putty to that didn't help, as-well as:
xterm-256color, putty, linux, screen.
setting Home/End to "rxvt" makes it recognize Home, but End gives no response.
what is the correct setting?
also, using "iocage console" with "exec_clean=1(def)" replaces variable term in jail to "xterm-256color", which contradicts to that flag description in ui&manual.
was it intentional? is there a workaround to specify another one?
iocage_lib/iocage.py:
running:
FreeNAS-11.2-U4.1
putty Release 0.71
if exec_clean: env_path = '/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:' \ '/usr/local/bin:/root/bin' env_lang = os.environ.get('LANG', 'en_US.UTF-8') su_env = { 'PATH': env_path, 'PWD': '/', 'HOME': '/', 'TERM': 'xterm-256color', 'LANG': env_lang, 'LC_ALL': env_lang }
running:
FreeNAS-11.2-U4.1
putty Release 0.71
