my booxed cooler died some weeks ago.
At the moment I am using a Scythe Mugen 2 RevB.
This guy is a bit to high, so the case does close but only with some pressure.
On the other hand I need the cooler for another pc.
First I wanted to order the Noctua NH-L12 because of the low profile > http://noctua.at/en/nh-l12.html
But I am sure the performance is not needed.
Is there a suggestion for a cheaper one? Hight should be no more then 150mm.
Maybe a passive one, because there will be enough ventilation in the case soon.
Air channels and 1 12cm fan for:
- each of the two driveracks
- CPU
Greetings from germany
heck
- CPU
heck
