Alright, I've been reading and pondering, and pondering and reading, and I think I've got the solution. I am getting the feeling that a 10 disk vdev might be too wide, but I was hindered, I thought, by a lack of cases that could hold twelve drives. I thought wrong. Check out this bad boy:
Fractal Design Define XL R2 Computer Case This thing is HUGE. It looks like the monolith from 2001. It has eight 3.5" slots, and 4 5.25" slots, so with the addition of a
4x3 SATA backplane, you get 12 drives. It's got the same silent features as the slightly smaller R5 case I was originally considering, but it's a bit more spacious inside. I can put an extra
140mm Fractal Design Silent R2 fan in the front to cool the bottom drive cage, there's another fan (included) on the bottom of the case, and one in the back (also included), for a total of four fans, but without compromising the silence. I ran my components through this
PSU calculator, and it appears my 450W Seasonic PSU will still be plenty, even with a total of 12 WD Reds (if anybody can see any gotchas, let me know). I'm going to put the case on one of these
CPU caddies to add some additional clearance underneath, and also to make it easier to move (it's rather heavy, esp. with 12 drives). Everything else can stay the same, only some cable extensions are needed to reach from the PSU to the motherboard (
12" 24-Pin Power Extension Cable,
9 1/2" 8-pin P8 Cable,
24" Latching Round SATA Cable).
This will allow me to have a zpool of 12 total drives composed of 2 6+2 RAIDZ2 vdevs. It will reduce the width of my vdevs, increase the IOPS, and give me 4 parity drives (two per vdev). I still get 42 TB of storage, less 20% for a total of 34 TB. I think that ought to do the trick.
So, Case Build Rev. 3:
Is 32 GB of RAM sufficient for 12 drives? Is a 450W PSU adequate for this rig (everything is low power, so I THINK it's okay - just wanted to double check)? If not, the same G Series comes in 550 and 650 as well.
Everything look copacetic?
Thanks for the great advice!
