Processor Upgrade, recommended Xeon?
nojohnny101
Here is my current hardware:
ASRock C226M WS Micro ATX
Intel Pentium G3258 Dual-Core 3.2GHz
Kingston DDR3 ECC Unbuffered (KVR16E11/8) 8gb x 4
Seagate NAS 3.5" 3TB x 6 (raidz2)
Sandisk Cruzer CZ33 16gb x 2 (mirrored) for boot
SeaSonic G Series SSR-550RM 550W Modular Plus Gold
Fractal Node 804
Noctua NF-F12 PWM (intake) & Noctua 140MM Premium Quiet (exhaust)
APC BR1000G 1000VA UPS
FreeNAS-11.0-U4 (54848d13b)
As per ASRock's website, here is the supported CPUs for the board:
Supports Intel® Xeon® E3-1200 v3/v4* and 5th/4th Generation Core™ i7/i5/i3/Pentium®/Celeron® Processors (Socket 1150)
- Supports Hyper-Threading Technology
- Supports Intel® Turbo Boost 2.0 Technology
*BIOS version 2.0 or above is required
**HDMI only works with certain Intel® E3 v3 CPUs(E3-1276 v3 /E3-1246 v3 /E3-1226v3 /E3-1275L v3 /E3-1286 v3/E3-1286L v3)
***Haswell i5/i7 processor support is an extended advantage provided by ASRock Rack. It is out of warranty; user's discretion is required.
Socket - Single socket H3 (LGA1150)
Chipset - Intel® C226
I am looking to upgrade my processor. I want more cores so I can transcode more media files (plex). I know sharing (SMB) benefits from higher clock speed but I am the only person that access the shares, so I don't think a downgrade in clock speed that would come with upgrading to a Xeon will make much of a difference.
I'm a bit lost on all the options and was hoping someone could make some recommendations. I am absolutely budget conscious so I don't need the top of the line, but I also don't want the lowest upgrade possible. I know the board is a bit limited in selection, but I am not upgrading the motherboard.
If I remember reading correctly, there isn't much value to be gained from going to the v4 from the v3, is that correct?
Thank you!
Stux
Get a Xeon E3-1230v4
Best bang for buck. Quad core hyperthreading.
Update your bios before upgrading.
Chris Moore
It might be less expensive to buy a board like mine complete with CPU and RAM than just to buy the CPU for your model system.
https://www.ebay.com/itm/TESTED-Super-Micro-X9SCM-F-Motherboard-w-E97379-001-Heatsink-I-O-Shield/232430611431	   --  $$90
https://www.ebay.com/itm/Genuine-Apple-Hynix-32GB-4x8GB-1866MHz-DDR3-ECC-Memory-for-Late-2013-Mac-Pro/272830002042  --  $180
https://www.ebay.com/itm/Intel-Xeon-E3-1230V2-CPU-3-30-ghz-SR0P4/232591059572									   --  $97
nojohnny101
@Stux thanks for the recommendation. That seems to be a hard processor to find. V3 and v5 are everywhere. Much of a difference besides price?
@Chris Moore I will check out your listings thanks!
Chris Moore
I am actually running the v1 revision of that processor, even older than the one I suggested, and I can transcode three streams easily.
Last night, I was running an rsync task between two pools in my server to backup data from my main pool to my backup pool and playing a stream on my 4k TV. The processor utilization was between 80 and 90% but there was never a glitch in the playback. That backup process between pools is the most resource intense thing my server does. Just playing videos on Plex, I have only gotten the CPU up to around 50% and that is with four streams going at once.
Stux
Don’t think v5 will work in your system. V3 is just a little bit slower, and uses slightly more power than v4 (haswell vs broadwell). Only real difference is TSX memory, which doesn’t matter to you I’m sure.
nojohnny101
I believe it. That's what I'm looking forward to, considering I'm coming from a dual core G3258, a xeon is going to blow it out of the water no matter what version it is. Thanks for sharing that though.
You're correct, v5 won't work. I think I'm going to go with a v3. I am currently bidding on a a e-1240v3 on eBay and might get it for $145, which seems like a pretty good deal to me.
nojohnny101
Thanks everyone for the help. I needed up going with the Xeon e3-1240 v3. Since it is the processor only, I have to get a cooler. I might try the Noctua NH-L9I, as it works with the processor but we'll have to see with my board.
