Problems with ZeroTier .... HELP!
Itay1778
Hey,
I encountered a problem running ZeroTier and I was able to connect to my network
But it does not create another interface
And I get the error PORT_ERROR
I tried to talk to their support but they did not really help me solve it
From my last conversation with them:
"It looks like something is preventing zerotier module from loading/working. There's no zerotier interface and the status has "PORT ERROR"
On Linux, it's the `tun` module. Not sure what to do for FreeBSD.
Sometimes the images on VPS hosts don't have tun for some reason and you need to get it running yourself."
I would be happy if you could help me with this
Thanks Itay
show us the output of ifconfig on your server with zerotier running. Maybe we will help you to see what's going on.
What command did you use to join the network (don't share your network ID here)?
Itay1778
It's at FreeNAS itself
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=2098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
        ether e0:69:95:2b:bf:5c
        hwaddr e0:69:95:2b:bf:5c
        inet 192.168.1.1 netmask 0xffffff00 broadcast 192.168.1.255
        inet 192.168.1.26 netmask 0xffffff00 broadcast 192.168.1.255
        inet 192.168.1.61 netmask 0xffffff00 broadcast 192.168.1.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
        groups: lo
        ether 02:04:e3:4e:45:00
        groups: bridge
        member: vnet0:35 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 4 priority 128 path cost 2000
        member: vnet0:25 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 7 priority 128 path cost 2000
        member: vnet0:24 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 8 priority 128 path cost 2000
        member: vnet0:22 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 5 priority 128 path cost 2000
        member: vnet0:21 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000
        member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 55
vnet0:21: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: Emby as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:c0:af:79
        hwaddr 02:84:10:00:06:0a
        nd6 options=1<PERFORMNUD>
        status: active
        groups: epair
vnet0:22: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: Nextcloud as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:27:9a:bf
        hwaddr 02:84:10:00:05:0a
        status: active
        groups: epair
vnet0:24: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: reverse_proxy as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:9f:9a:97
        hwaddr 02:84:10:00:08:0a
        status: active
        groups: epair
vnet0:25: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: wordpress as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:ed:53:08
        hwaddr 02:84:10:00:07:0a
        status: active
        groups: epair
vnet0:35: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: ZeroTier_TC as nic: epair0b
        options=8<VLAN_MTU>
        ether 02:ff:60:43:da:28
        hwaddr 02:84:10:00:04:0a
        status: active
        groups: epair
It's in the jail of ZeroTier
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
        groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:ff:60:43:da:29
        hwaddr 02:84:10:00:09:0b
        inet 192.168.1.51 netmask 0xffffff00 broadcast 192.168.1.255
        status: active
        groups: epair
zerotier-cli join mynetwork
OK, so I confirm you have no zerotier adapter in that output.
My understanding was that the zerotier network should run on the host and be bridged to whatever jails (perhaps with a dedicated VNET interface) needed.
What happens if you run that command on the host instead?
Itay1778
Do you want me to install ZeroTier on the FreeNAS itself ?? And I do not think it's the most safe to install it directly on FreeNAS
Or just the command of connecting to the network ??? Because I do not think it will work because there is no ZeroTier installed on FreeNAS according to what I know.
Did you also run zerotier-one -d first?
ZeroTier is already installed on FreeNAS from some version around 11.0.
Itay1778
Itay1778
On FreeNAS. In my opinion, you don't need a jail for zerotier itself.
Ok
I delete the jail and start from scratch
And I will try with zerotier-one -d
And if that fails I will think whether to install on FreeNAS itself. Because I think it's much more likely to install such things on jails
So to be clear and in one single message:
start the zerotier daemon:
zerotier-one -d
Join a network:
zerotier-cli join networkID
you get a response like this
ztcxxxxxxxxxx 200 join OK
where ztcxxxxxxxxxx is the new interface
then you can bridge the new interface to your selected VNET... and work out the routing you want to have happening, since the VNET will not normally be on the same subnet/IP range as your zerotier network, so routing or some kind of accordance with the addressing scheme will be needed to make any of it useful.
I guess you could play with the zerotier bridging mode for that interface (on their website) and perhaps then the zerotier network would just become part of your bridged network directly and follow the local addressing scheme.
Itay1778
Ok at the end I gave up and hooked up on the FreeNAS itself!
And everything works !! I have another interface and I get IP from the network
And now I can create another interface in ui and also it appears in ifconfig.
So thanks for the help !!!
Itay1778
zerotier-one -d
Join a network:
Hey a little question
Is there a possibility to stop the zerotier? Or something like that?
The problem is that the support is... well... "half-baked" would be an overly-charitable description. There's no GUI support at all, the service isn't enabled at boot, and the biggest problem is that the host address changes on reboot. And based on the bug ticket I filed, the devs don't seem to be in the least bit interested in improving it.
Itay1778
zerotier-one -d
Join a network:
Hey, can you please explain to me how i can set two interfaces to jail one interface of zerotier with zerotier's IP. And the other with the IP that I set for him like I did for every jail until now that he had access to the Internet
I hope I was clear what I wanted to do:).
I guess there are a couple of ways to think about that...
you can unjoin the network
you can kill the zerotier-one process
One day, when the GUI has support for zerotier, you may be able to do that under services in the GUI... for now, not an option.
Itay1778
I thought about the unjoin, but I would still want him to be inside the network just turned off.
So I understand that for now the only way is to kill the process?
So what is the command to do this?
And how do I turn it back on?
Itay1778
Ok I managed
@sretalla
Can you help me with this please:)
To create yourself another bridge and add the zerotier network adapter to it, you would do something like this:
ifconfig bridge1 create
ifconfig bridge1 addm ztcxxxxxxxxx up
Then you need some help from someone who really knows how to do what you're asking for, which is to have 2 VNET NICs in a jail, one bridged to bridge0 and the other bridged to bridge1... I haven't got enough time to work it out right now.
Itay1778
When do I create this bridge1 it also creates VNET1?
