Hi all!
Before the upgrade to 11.2 I used the FreeNAS gui to create warden based jails. Installing ZeroTier in them was rather simple:
1. Install ZeroTier
2. Run the service
3. Join your ZeroTier netwerk
4. Et voila!
But now as I am trying to migrate all stuff I have in warden jails to iocage jails, it isn't as straightforward anymore. ZeroTier can't connect to the network and I think this is because the iocage jail doesn't have the correct privileges. I also think ZeroTier can't access the ZT network device, but I am not sure. I tried the virtual vnet adapter and most combinations of checkbox privileges that seemed reasonable, to no avail.
Some errors/outputs:
I have zero experience with iocage and could not find any helpful resource on the internet on ZeroTier in iocage jails. Does anyone here use ZeroTier and if so, how do you configure the jail to make it work? :)
Some system information (as per forum rules):
- FreeNAS-11.2-RELEASE-U1 (clean install)
- Intel Xeon E5-1650 v4
- 64 GB RDIMM
- 8*8 TB in raidz3 (on IBM M1015)
- Intel X520-DA2 (LC 10 Gb/s)
- No VLANs, LACP or other added complexities
If you need more information, let me know
1. Install ZeroTier
2. Run the service
4. Et voila!
# zerotier-one -d ERROR: unable to configure virtual network port: cannot find /dev node for newly create tap device # service zerotier start zerotier already running? (pid=89858) # zerotier-cli listnetworks 200 listnetworks *network* *mac* PORT_ERROR PRIVATE - # zerotier-cli status 200 info *network* 1.2.12 OFFLINE
- 64 GB RDIMM
