Hi folks,
I have a problem with Jails (and maybe FreeNAS).
I have been trying to do this already on FreeNAS 9.3 and now on 9.10 with no success.
I am attempting to install qBitTorrent manually in a jail. There is a tutorial here in the forum that I am following. Unfortunately, I cannot use some basic commands, like:
I tried pkg-static bootstrap -f and got this result:
Running uname -a in the jail gives me this:
Running uname -a in FreeNAS I get this:
I cannot install nano, I get this:
EDIT:
Here is the pkg repo:
/EDIT
Running the above suggested pkg-static install -f pkg has this result:
Basically nothing is working. I cannot use pkg, portmaster etc. I cannot install anything or use the jail in any meaningful way. How can I fix this?
One more thought. I thought that FreeNAS is actually running on FreeBSD 9.x, however, uname shows that it is FreeBSD 10.x ... strange.
Lastly, my current freeNAS version:
Hope somebody can help.
Thanks.
pkg update pkg upgrade pkg install nano portmaster
root@Torrent:/ # pkg-static bootstrap -f pkg(8) is already installed. Forcing reinstallation through pkg(7). The package management tool is not yet installed on your system. Do you want to fetch and install it now? [y/N]: y Bootstrapping pkg from pkg+http://pkg.FreeBSD.org/freebsd:9:x86:64/latest, please wait... pkg-static: Warning: Major OS version upgrade detected. Running "pkg-static install -f pkg" recommended [Torrent] Installing pkg-1.7.1... pkg-static: wrong architecture: FreeBSD:9:amd64 instead of FreeBSD:10:amd64 package pkg is already installed, forced install [Torrent] Extracting pkg-1.7.1: 100%
root@Torrent:/ # uname -a FreeBSD Torrent 10.3-RELEASE FreeBSD 10.3-RELEASE #0 52dd777(freebsd10): Fri Mar 25 14:48:36 PDT 2016 root@build.ixsystems.com:/tank/home/nightlies/build-freenas9/_BE/objs/tank/home/nightlies/build-freenas9/_BE/trueos/sys/FreeNAS.amd64 amd64
[root@freenas] /# uname -a FreeBSD freenas.oldman.local 10.3-RELEASE FreeBSD 10.3-RELEASE #0 52dd777(freebsd10): Fri Mar 25 14:48:36 PDT 2016 root@build.ixsystems.com:/tank/home/nightlies/build-freenas9/_BE/objs/tank/home/nightlies/build-freenas9/_BE/trueos/sys/FreeNAS.amd64 amd64
[root@freenas] /# pkg install nano Updating local repository catalogue... pkg: file:///usr/ports/packages/meta.txz: No such file or directory repository local has no meta file, using default settings pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory Unable to update repository local All repositories are up-to-date. Checking integrity... done (0 conflicting) The most recent version of packages are already installed
EDIT:
FreeBSD: {
url: "pkg+http://pkg.FreeBSD.org/freebsd:9:x86:64/latest",
mirror_type: "srv",
enabled: yes
/EDIT
[root@freenas] /# pkg-static install -f pkg
pkg-static: file:///usr/ports/packages/meta.txz: No such file or directory
pkg-static: file:///usr/ports/packages/packagesite.txz: No such file or directory
The following 1 package(s) will be affected (of 0 checked):
Installed packages to be REINSTALLED:
pkg-1.6.2
4 MiB to be downloaded.
Proceed with this action? [y/N]: y
pkg-static: archive_read_open_filename(/usr/ports/packages/All/pkg-1.6.2.txz): Failed to open '/usr/ports/packages/All/pkg-1.6.2.txz'
Current Train: FreeNAS-9.10-STABLE (Installed OS)
Thanks.
