problems with FAILOVER link aggregation
Hyffer
I tried to create a failover link aggregation network interface, but encountered some problems. The "MII Polling Interval" is always 0, so that it cannot detect a slave failure and switch to another card. (No matter using TrueNAS CLI or Web UI to create link aggregation, it is the same result.)
root@truenas[~]# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v5.15.79+truenas
Bonding Mode: fault-tolerance (active-backup)
Primary Slave: enp1s0 (primary_reselect always)
Currently Active Slave: enp1s0
MII Status: up
MII Polling Interval (ms): 0                   <----- HERE
Up Delay (ms): 0
Down Delay (ms): 0
Peer Notification Delay (ms): 0
Slave Interface: eno1
MII Status: up
Speed: 100 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: [...]
Slave queue ID: 0
Slave Interface: enp1s0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Slave queue ID: 0
If I unplug an ethernet cable, a device down event raises (shows in dmesg), but still "MII Status: up".
My temporary workaround​
Change the content of file /sys/class/net/bond0/bonding/miimon from 0 to 100 can solve this problem. (It is definitely not recommended)
System Info​
TrueNAS-SCALE-22.12.0
two network card: Intel I219-V and Realtek RTL8125b
I found this related to my problem: Add the mii monitoring during bond creation. It shows this issue has been fixed. But in my case, it seems not.
And by the way, web ui suggests "The order is important because the FAILOVER lagg protocol will mark the first interface as the "primary" interface."
But I tried that the order doesn't matter. In this situation, it just chooses Realtek RTL8125b as primary.
Are these bugs, or am I missing something?
lawlest
I have been using a Pre-Init script that just does "echo 100 > /sys/class/net/bond0/bonding/miimon" and it seems to be good enough until the problem gets fixed.
Constantin
Vampire Pig
I never got Failover LAGG to work on my first FreeNAS (Mini XL) so I'm not surprised it took additional work to get fixed. Congrats on finding the source of the issue and a solution.
Gustav
Hi. i have same issues with this
Do somebody find a Solution ? it is reported to TrueNas Support ?
morganL
Captain Morgan
Administrator
Please report details of software/hardware and did you use the pr-init script above?
etherion
I have the same problem. Truenas scale does not switch between the adapters when we have it set as an active backup.
it is because MII Polling Interva is 0
so I created a script as suggested that runs on reboot that will set miimon
Create a Script (e.g., /root/set_miimon.sh):
#!/bin/bash
Make the script executable:
chmod +x /root/set_miimon.sh
Add the Script to Root's Crontab:
Edit the root user's crontab:
sudo crontab -e
Add the line:
@Reboot /root/set_miimon.sh
sudo crontab -e
Well that's not going to survive long...
You need to do that in the GUI, System Settings | Advanced | Cron Jobs if you want it to stay there.
Gustav
yes..temporary. but TrueNas guys have to fix it. i hope it.
