I am using latest TrueNAS SCALE 22.12.1
I am trying to manually install transmission daemon. Via the "Launch Docker Image" menu.
However, it errors out with the following message:
The dataset in question, /mnt/data/torrents, is indeed an NFS(4) share.
This is how I usually set this up, I'm using "torrents" directory as a place where all finished torrents will reside until they are sorted and sent elsewhere.
This setup also allows the consumption of unsorted torrents via for example Kodi and the NFS mount.
However, Truenas Scale seems to have an issue with the intended setup.
What would be the workaround for this issue?
Thanks.
Thanks.
