Problem with folder tree.
s3r3ft
How are you
I have a problem with a dataset tree, since I create a root dataset called mantenimiento, and within this I want to put other datasets.
The problem is that when I enter the file browser, I see the main mantenimiento folder, but besides having the datasets inside this folder, they also appear on the outside, how can I avoid this?, pruebauno is inside mantenimiento, but I do not want pruebauno to look outside.
pro lamer
@s3r3ft the inner datasets are separate filesystems and they are separate by the design.
Is the contents of pruebauno share the same as pruebauno subfolder? (Subfolder aka mantenimiento/pruebauno)
Sent from my phone
PhilipS
You should only have to setup the share on the root folder. If you don't see the nested dataset in the shared root dataset, then it is probably permission related.
tfran1990
looks like you made 2 share directory.
use mantenimiento as the share then put the pruebauno folder inside of it.
if you want to provide different permissions for the pruebauno folder dont set permissions recursive or it will apply to everything in that folder.
