SOLVED Problem with Broadcom NetXtreme II 10 Gigabit Ethernet (BCM57840)
sirszabo
Dear All,
I have a problem with FreeNAS-11.1-U4 (bare metal) installation with Broadcom NetXtreme II 10 Gigabit Ethernet (BCM57840) card.
The correct model/type is -> https://www.asus.com/us/Commercial-Servers-Workstations/PEB10G578402T/
The NAS connected directly in two VMware ESXi 6.5 host, where also these cards has been installed.
When I configured the communication between NAS and the VMware hosts, the connection dropping in every minute.
First I think I have a problem with VMware and card compatibility. Therefore I made temporary a direct communication between the two VMware host via the 10Gigabit port, but in this way the communication was stable.
Here is the NAS errors:
pciconf -lv
bxe0@pci0:2:0:0: class=0x020000 card=0x866e1043 chip=0x16a114e4 rev=0x11 hdr=0x00
vendor = 'Broadcom Limited'
device = 'BCM57840 NetXtreme II 10 Gigabit Ethernet'
class = network
subclass = ethernet
bxe1@pci0:2:0:1: class=0x020000 card=0x866e1043 chip=0x16a114e4 rev=0x11 hdr=0x00
class = network
subclass = ethernet
dmesg
bxe0: link_vars phy_flags : 1
bxe1: link_vars phy_flags : 1
bxe1:
bxe1: link state changed to UP
NIC Link is Up, 10000 Mbps full duplex, Flow control: ON - receive & transmit
bxe0:
bxe0: link state changed to UP
bxe1: link_vars phy_flags : 5
bxe1: link state changed to DOWN
bxe0: link state changed to DOWN
VMware log:
2018-04-18T10:42:41.433Z cpu24:2097869)qfle3: qfle3_report_link:3702: [vmnic4] Pausing TX Queues On Link down
2018-04-18T10:42:41.433Z cpu24:2097869)qfle3: qfle3_report_link:3717: [vmnic4] NIC Link is Down
2018-04-18T10:42:51.732Z cpu24:2097869)qfle3: qfle3_report_link:3737: [vmnic4] Resuming TX Queues On Link up
2018-04-18T10:42:51.732Z cpu24:2097869)qfle3: qfle3_report_link:3777: [vmnic4] NIC Link is Up, 10000 Mb/s full duplex, Flow control: ON - receive & transmit
2018-04-18T10:42:54.664Z cpu6:2097292)NetqueueBal: 5030: vmnic4: device Up notification, reset logical space needed
2018-04-18T10:42:54.664Z cpu6:2097292)NetPort: 1580: disabled port 0x6000002
2018-04-18T10:42:54.664Z cpu16:2107634)NetSched: 654: vmnic4-0-tx: worldID = 2107634 exits
2018-04-18T10:42:54.664Z cpu3:2107635)NetSched: 654: vmnic4-1-tx: worldID = 2107635 exits
2018-04-18T10:42:54.664Z cpu14:2107636)NetSched: 654: vmnic4-2-tx: worldID = 2107636 exits
2018-04-18T10:42:54.664Z cpu7:2107638)NetSched: 654: vmnic4-4-tx: worldID = 2107638 exits
2018-04-18T10:42:54.664Z cpu31:2107639)NetSched: 654: vmnic4-5-tx: worldID = 2107639 exits
2018-04-18T10:42:54.664Z cpu16:2107637)NetSched: 654: vmnic4-3-tx: worldID = 2107637 exits
2018-04-18T10:42:54.664Z cpu3:2107640)NetSched: 654: vmnic4-6-tx: worldID = 2107640 exits
2018-04-18T10:42:54.664Z cpu4:2107641)NetSched: 654: vmnic4-7-tx: worldID = 2107641 exits
2018-04-18T10:42:54.665Z cpu6:2097292)Uplink: 11680: enabled port 0x6000002 with mac 2c:4d:54:45:9a:8f
2018-04-18T10:42:54.707Z cpu6:2097292)WARNING: qfle3: qfle3_tq_stop:921: [vmnic4] Stopping TX queue 1 in kernel
2018-04-18T10:42:54.710Z cpu6:2097292)WARNING: qfle3: qfle3_tq_stop:921: [vmnic4] Stopping TX queue 2 in kernel
2018-04-18T10:42:54.713Z cpu6:2097292)WARNING: qfle3: qfle3_tq_stop:921: [vmnic4] Stopping TX queue 3 in kernel
2018-04-18T10:42:54.716Z cpu6:2097292)WARNING: qfle3: qfle3_tq_stop:921: [vmnic4] Stopping TX queue 4 in kernel
2018-04-18T10:42:54.719Z cpu6:2097292)WARNING: qfle3: qfle3_tq_stop:921: [vmnic4] Stopping TX queue 5 in kernel
2018-04-18T10:42:54.722Z cpu6:2097292)WARNING: qfle3: qfle3_tq_stop:921: [vmnic4] Stopping TX queue 6 in kernel
2018-04-18T10:42:54.725Z cpu6:2097292)WARNING: qfle3: qfle3_tq_stop:921: [vmnic4] Stopping TX queue 7 in kernel
2018-04-18T10:42:54.728Z cpu6:2097292)Uplink: 537: Driver claims supporting 7 RX queues, and 7 queues are accepted.
2018-04-18T10:42:54.728Z cpu6:2097292)Uplink: 533: Driver claims supporting 7 TX queues, and 7 queues are accepted.
2018-04-18T10:42:54.728Z cpu6:2097292)NetPort: 1580: disabled port 0x6000002
2018-04-18T10:42:54.728Z cpu22:2107668)NetSched: 654: vmnic4-0-tx: worldID = 2107668 exits
2018-04-18T10:42:54.728Z cpu6:2097292)Uplink: 11680: enabled port 0x6000002 with mac 2c:4d:54:45:9a:8f
2018-04-18T10:42:54.728Z cpu6:2097292)WARNING: qfle3: qfle3_rx_ustorm_prods_offset:54: [vmnic4] rx prods offset 25024
2018-04-18T10:42:54.729Z cpu6:2097292)WARNING: qfle3: qfle3_rx_ustorm_prods_offset:54: [vmnic4] rx prods offset 25056
2018-04-18T10:42:54.731Z cpu6:2097292)WARNING: qfle3: qfle3_rx_ustorm_prods_offset:54: [vmnic4] rx prods offset 25088
2018-04-18T10:42:54.732Z cpu6:2097292)WARNING: qfle3: qfle3_rx_ustorm_prods_offset:54: [vmnic4] rx prods offset 25120
2018-04-18T10:42:54.734Z cpu6:2097292)WARNING: qfle3: qfle3_rx_ustorm_prods_offset:54: [vmnic4] rx prods offset 25152
2018-04-18T10:42:54.735Z cpu6:2097292)WARNING: qfle3: qfle3_rx_ustorm_prods_offset:54: [vmnic4] rx prods offset 25184
2018-04-18T10:42:54.737Z cpu6:2097292)WARNING: qfle3: qfle3_rx_ustorm_prods_offset:54: [vmnic4] rx prods offset 25216
Could you please somebody can help for me to debug or solve this issue?
Maybe the FreeNAS not supporting this device?
Many thanks!
Chris Moore
In my signature is a button called " useful links " and in there is a primer on 10G network for FreeNAS. The model recommend is (if I recall correctly) an Intel or Chelsio. I can't remember the model number. Broadcom is not a recommendation because of driver support.
sirszabo
Thanks for your answer Chris!
Previously I don't know about the Broadcom "gap" ...
Because I bought 3pcs. of this card I would like to use it. (I hope it is possible)
The FreeBSD supporting the bxe drivers (as I know) since the version 10. In this way the FreeNAS 11 need to support also.
Right now I checked deeper a bit the FreeNAS regarding the driver and firmware version.
Port1:
dev.bxe.0.pci_link: 5.0GT/s x8
dev.bxe.0.mac_addr: 2c:4d:54:45:99:27
dev.bxe.0.mf_mode: Single
dev.bxe.0.fw_version: 7.13.1.0
dev.bxe.0.bc_version: 7.13.0
dev.bxe.0.mf_vnics: 1
dev.bxe.0.version: 1.78.90
dev.bxe.0.%parent: pci2
dev.bxe.0.%pnpinfo: vendor=0x14e4 device=0x16a1 subvendor=0x1043 subdevice=0x866e class=0x020000
dev.bxe.0.%location: slot=0 function=0 dbsf=pci0:2:0:0
dev.bxe.0.%driver: bxe
dev.bxe.0.%desc: QLogic NetXtreme II BCM57840 4x10GbE (B1) BXE v:1.78.90
Port2:
dev.bxe.1.pci_link: 5.0GT/s x8
dev.bxe.1.mac_addr: 2c:4d:54:45:99:29
dev.bxe.1.mf_mode: Single
dev.bxe.1.fw_version: 7.13.1.0
dev.bxe.1.bc_version: 7.13.0
dev.bxe.1.mf_vnics: 1
dev.bxe.1.version: 1.78.90
dev.bxe.1.%parent: pci2
dev.bxe.1.%pnpinfo: vendor=0x14e4 device=0x16a1 subvendor=0x1043 subdevice=0x866e class=0x020000
dev.bxe.1.%location: slot=0 function=1 dbsf=pci0:2:0:1
dev.bxe.1.%driver: bxe
dev.bxe.1.%desc: QLogic NetXtreme II BCM57840 4x10GbE (B1) BXE v:1.78.90
On the VMware side also checked the driver:
Driver Info:
Bus Info: 0000:08:00:0
Driver: qfle3
Firmware Version: FW: 7.13.3.0 BC: 7.13.0
Version: 1.0.60.0
The all three cards has been arrived with firmware version 7.12.81.
I think the driver miss match cause this communication error.
jdbrant
The problem caused by a hardware error. The card has been replaced to a new one, and everything works now!
Curious if you replaced it with the same model adapter? or did you change to an adapter with a different chip?
sirszabo
Hey jdbrant,
It is replaced to the same model! Since ~1 year ago I don't have any issues with this card!
If you need any evidence, or need any help from my side pls. let me know!
p.s.: NAS server is a Supermicro one, and the two VMware 6.5 server is installed on the HPE DL380 Gen9.
jdbrant
Hey jdbrant,
I was curious because we have been having the same kind of issue however we have the 10gb broadcom card installed in a freenas unit running on the DL380 Gen9.
For the mean time we have moved the connectivity to the build in adapters in lagg format using two of the nics. I think we may just bite the bullet and order a couple of chelsio 10gb cards as we have 2 nas units one primary and one secondary at a dr site. The primary one would drop the network connection and then any files written during the drop would just be gone. Either way it caused me a lot of grief. Thanks for getting back to me so quickly though its much appreciated.
jdbrant
Here's one for yah. Turns out it isnt even the network adapter. Server is randomly resetting itself so it just reboots at random. Trying a firmware update this evening to see if it resolves the issue from there is a support call to hp.
