Pliqui
- Apr 24, 2018
I recently finished my new build and I had some troubles with a Qlogci QLE8152 NICs, ESXi 6.5 recognized them but the NICs where not able to provide a link. As a replacement I ordered a NIC based on intel chipset 82599ES model X520-DA2 (10Gtek Brand) and got recognized intermediately by ESXi, but since Wednesday 06/20 I'm not being able to figure it out why I'm getting slow speeds.
VMware:
CPU: Intel(R) Xeon(R) CPU W3550 @ 3.07GHz
Mobo: Lenovo Workstation S20
RAM: 24Gb non-ECC (maxed out)
Raid Controller: IBM ServeRaid M5015 (Cross-flashed to LSI 9260-8i)
HDD1: 1 x Samsumg 850 EVO 250gb SSD (Boot device for VMs and boot disks for some vms)
HDD2: 4 x HGST DeskStar NAS 3.5" 4TB 7200 RPM 128MB in Raid5 (1 Datastore)
NIC: 1 x 1gb - Management network
10GB NIC: 10Gtek X520-DA2 (vmnic1 and vmnic2)
FreeNAS:
CPU: Intel Xeon E3-1230 V6 Kaby Lake 3.5 GHz
Mobo: SUPERMICRO MBD-X11SSL-CF Micro ATXa
RAM: 4 x Crucial CT16G4WFD824A 16Gb Ddr4 Ecc Unbuff Cl17 (64Gb maxed out)
Boot: 1 x 128gb SSD
HDD1: 4 x HGST Deskstar NAS 3.5" 8TB 7200 RPM 128MB stripped-mirror
SSD1: 1 x Intel Solid State Drive DC S3110 128GB for ZLOG
SSD2: 4 x 128 SSD Stripe (for testing purporse)
10GB NIC1: NetApp Chelsio Dual Port SFP+ 10GbE PCIe 111-00603+A0 CC2-S320E-SR 100-1082-00
The cables used are 2 x 10Gtek for Cisco SFP-H10GB-CU1M,10GBASE-CU Direct Attach Copper Cable, Twinax Cable, Passive, 1-Meter
Zpool List
When I got the build, the first thing I did was to performe some IO tests using sync standard and always on the VMWARE zpool (created 2 zvol)
This was run inside a Debian 9 VM.
Sync = Standard
Sync = Always
When I transferred one virtual machine to the new iSCSI datastore it was slow, so the path into the rabbit hole started.
The network is configured as follow: at this point everything is setup vanilla.
Running iperf from ESXi to Freenas
Right now, since I got the host under maintenance mode and no load I got this
But the second I fire up a vm, doesn't matter the size I got between 1.8 Gbits/sec to ~2.5 Gbits/sec
The max transfer is around 300-400.
Transfer a 2 TB VM took 7h:22min and a 8TB took 20H 45 Min. But moving back the 2TB VM took 2h:58 mins
And when I transfered 9 VMs to 3 different DS (at this point all were sync=always), 1 for general VMs shared, 1 exclusive for Veeam and 1 for the file server. Powered them all and ran a Veeam backup job... the whole ESXi became unresponsive and I got these errors.
I understand that I only have 4 vdevs in stripe-mirror and I will not saturate 10GB, but that should be faster than my raid5 and the striped ssd. But not even iperf??
What I have tried:
EDIT 1: Change CMD tags to CODE tags
EDIT 2: Disk Model
VMware:
![9V99cbX.png](https://i.imgur.com/9V99cbX.png)
FreeNAS:
Boot: 1 x 128gb SSD
[root@freenas ~]# ifconfig cxgb0 cxgb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6c07bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:07:43:08:42:f4 hwaddr 00:07:43:08:42:f4 inet 10.0.0.2 netmask 0xffffff00 broadcast 10.0.0.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet 10Gbase-Twinax <full-duplex> status: active
[root@freenas ~]# ifconfig cxgb1 cxgb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=6c07bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> ether 00:07:43:08:42:f5 hwaddr 00:07:43:08:42:f5 inet 10.0.1.2 netmask 0xffffff00 broadcast 10.0.1.255 nd6 options=9<PERFORMNUD,IFDISABLED> media: Ethernet 10Gbase-Twinax <full-duplex> status: active
Zpool List
[root@freenas ~]# zpool list -v NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT Test_SSD 468G 223G 245G - 2% 47% 1.00x ONLINE /mnt gptid/a850b6bf-77bf-11e8-b7b0-ac1f6b83f450 117G 55.3G 61.7G - 2% 47% gptid/a88ea704-77bf-11e8-b7b0-ac1f6b83f450 117G 55.1G 61.9G - 3% 47% gptid/a8d40f00-77bf-11e8-b7b0-ac1f6b83f450 117G 47.7G 69.3G - 3% 40% gptid/a9496891-77bf-11e8-b7b0-ac1f6b83f450 117G 64.8G 52.2G - 3% 55% VMWARE 14.5T 10.3T 4.25T - 5% 70% 1.00x ONLINE /mnt mirror 7.25T 5.11T 2.14T - 6% 70% gptid/e2a521ff-7687-11e8-99bb-ac1f6b83f450 - - - - - - gptid/e3224228-7687-11e8-99bb-ac1f6b83f450 - - - - - - mirror 7.25T 5.14T 2.11T - 5% 70% gptid/e3a8244e-7687-11e8-99bb-ac1f6b83f450 - - - - - - gptid/e41f26ad-7687-11e8-99bb-ac1f6b83f450 - - - - - - log - - - - - - gptid/e459c976-7687-11e8-99bb-ac1f6b83f450 119G 384K 119G - 0% 0% freenas-boot 118G 1.11G 117G - - 0% 1.00x ONLINE - ada1p2 118G 1.11G 117G - - 0%
Sync = Standard
fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=random_read_write.fio --bs=4k --iodepth=64 --size=4G --readwrite=randrw --rwmixread=75 fio-2.16 Starting 1 process test: Laying out IO file(s) (1 file(s) / 4096MB) Jobs: 1 (f=1): [m(1)] [100.0% done] [154.8MB/53280KB/0KB /s] [39.7K/13.4K/0 iops] [eta 00m:00s] test: (groupid=0, jobs=1): err= 0: pid=1267: Wed Jun 20 21:13:30 2018 read : io=3070.4MB, bw=80247KB/s, iops=20061, runt= 39179msec write: io=1025.8MB, bw=26808KB/s, iops=6702, runt= 39179msec cpu : usr=10.66%, sys=32.24%, ctx=22131, majf=0, minf=9 IO depths : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0% submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0% issued : total=r=785996/w=262580/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0 latency : target=0, window=0, percentile=100.00%, depth=64 Run status group 0 (all jobs): READ: io=3070.4MB, aggrb=80246KB/s, minb=80246KB/s, maxb=80246KB/s, mint=39179msec, maxt=39179msec WRITE: io=1025.8MB, aggrb=26808KB/s, minb=26808KB/s, maxb=26808KB/s, mint=39179msec, maxt=39179msec Disk stats (read/write): sdb: ios=785006/262268, merge=0/61, ticks=1190340/889084, in_queue=2079088, util=99.98%
Sync = Always
fio --randrepeat=1 --ioengine=libaio --direct=1 --gtod_reduce=1 --name=test --filename=test --bs=4k --iodepth=64 --size=4G --readwrite=randrw --rwmixread=75 fio-2.16 Starting 1 process test: Laying out IO file(s) (1 file(s) / 4096MB) Jobs: 1 (f=1): [m(1)] [100.0% done] [47356KB/16180KB/0KB /s] [11.9K/4045/0 iops] [eta 00m:00s] test: (groupid=0, jobs=1): err= 0: pid=1538: Wed Jun 20 21:25:05 2018 read : io=3070.4MB, bw=79202KB/s, iops=19800, runt= 39696msec write: io=1025.8MB, bw=26459KB/s, iops=6614, runt= 39696msec cpu : usr=10.61%, sys=38.78%, ctx=19718, majf=0, minf=9 IO depths : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0% submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0% complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0% issued : total=r=785996/w=262580/d=0, short=r=0/w=0/d=0, drop=r=0/w=0/d=0 latency : target=0, window=0, percentile=100.00%, depth=64 Run status group 0 (all jobs): READ: io=3070.4MB, aggrb=79201KB/s, minb=79201KB/s, maxb=79201KB/s, mint=39696msec, maxt=39696msec WRITE: io=1025.8MB, aggrb=26459KB/s, minb=26459KB/s, maxb=26459KB/s, mint=39696msec, maxt=39696msec Disk stats (read/write): sdb: ios=782880/261557, merge=1/9, ticks=1080076/835584, in_queue=1915504, util=99.97%
cxgb0 iSCSI-0 Active 10.0.0.2 --> iSCSI vDS --> iSCSI-PG1 --> vmkernel1 (10.0.0.3) --> vmnic1 cxgb1 iSCSI-0 Active 10.0.1.2 --> iSCSI vDS --> iSCSI-PG2 --> vmkernel2 (10.0.1.3) --> vmnic2
[root@esxi01:/usr/lib/vmware/vsan/bin] ./iperf3.copy -c 10.0.1.2 Connecting to host 10.0.1.2, port 5201 [ 4] local 10.0.1.3 port 11121 connected to 10.0.1.2 port 5201 iperf3: getsockopt - Function not implemented [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 410 MBytes 3.44 Gbits/sec 8626536 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 1.00-2.00 sec 152 MBytes 1.27 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 2.00-3.00 sec 276 MBytes 2.32 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 3.00-4.00 sec 187 MBytes 1.57 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 4.00-5.00 sec 232 MBytes 1.95 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 5.00-6.00 sec 229 MBytes 1.92 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 6.00-7.00 sec 183 MBytes 1.54 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 7.00-8.00 sec 175 MBytes 1.47 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 8.00-9.00 sec 219 MBytes 1.83 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 9.00-10.00 sec 182 MBytes 1.53 Gbits/sec 4286340760 0.00 Bytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 2.19 GBytes 1.88 Gbits/sec 0 sender [ 4] 0.00-10.00 sec 2.19 GBytes 1.88 Gbits/sec receiver
[root@esxi01:/usr/lib/vmware/vsan/bin] ./iperf3 -c 10.0.1.2 Connecting to host 10.0.1.2, port 5201 [ 4] local 10.0.1.3 port 11095 connected to 10.0.1.2 port 5201 iperf3: getsockopt - Function not implemented [ ID] Interval Transfer Bandwidth Retr Cwnd [ 4] 0.00-1.00 sec 725 MBytes 6.09 Gbits/sec 8626536 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 1.00-2.00 sec 726 MBytes 6.09 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 2.00-3.00 sec 725 MBytes 6.08 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 3.00-4.00 sec 728 MBytes 6.11 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 4.00-5.00 sec 732 MBytes 6.14 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 5.00-6.00 sec 726 MBytes 6.09 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 6.00-7.00 sec 730 MBytes 6.12 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 7.00-8.00 sec 732 MBytes 6.14 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 8.00-9.00 sec 731 MBytes 6.13 Gbits/sec 0 0.00 Bytes iperf3: getsockopt - Function not implemented [ 4] 9.00-10.00 sec 724 MBytes 6.07 Gbits/sec 4286340760 0.00 Bytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 7.11 GBytes 6.11 Gbits/sec 0 sender [ 4] 0.00-10.00 sec 7.11 GBytes 6.11 Gbits/sec receiver
- From the RAID5 to a Datastore created on top of the 4 x 128gb SSD and sync=disabled
![9tTfAhM.png](https://i.imgur.com/9tTfAhM.png)
- From the RADI5 to a Dastore on top of the 4 x 8TB Stripe-mirror and sync=standard
![BzdFwKf.png](https://i.imgur.com/BzdFwKf.png)
2018-06-24T03:14:03.310Z cpu7:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4571: vmnic1 : scheduler(0x4304780af120)/device(0x430250c61080) 1/0 lock up [stopped=0]: 2018-06-24T03:14:03.310Z cpu7:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4578: detected at 97938998 while last xmit at 97933998 and 36524 bytes in flight [window 86460 bytes] 2018-06-24T03:14:03.310Z cpu7:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4583: and last enqueued/dequeued at 97933997/97933997 [stress 0] 2018-06-24T03:14:03.310Z cpu7:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4586: with 478 pkts inflight 2018-06-24T03:14:03.488Z cpu0:65934)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:03.488Z cpu0:65934)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:04.490Z cpu2:65930)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:04.490Z cpu2:65930)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:05.491Z cpu0:65940)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:05.491Z cpu0:65940)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:06.493Z cpu0:65943)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:06.493Z cpu0:65943)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:07.495Z cpu2:65934)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:07.495Z cpu2:65934)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:08.497Z cpu2:65930)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:08.497Z cpu2:65930)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:09.310Z cpu6:106438)VSCSI: 2891: handle 8230(vscsi1:1):Reset [Retries: 40/0] from (vmm0:obiwan.abocor.com) 2018-06-24T03:14:09.310Z cpu0:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4571: vmnic1 : scheduler(0x4304780af120)/device(0x430250c61080) 1/1 lock up [stopped=0]: 2018-06-24T03:14:09.310Z cpu0:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4578: detected at 97944998 while last xmit at 97938998 and 36524 bytes in flight [window 86460 bytes] 2018-06-24T03:14:09.310Z cpu0:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4583: and last enqueued/dequeued at 97938998/97938998 [stress 0] 2018-06-24T03:14:09.310Z cpu0:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4586: with 478 pkts inflight 2018-06-24T03:14:09.310Z cpu0:76124)WARNING: netschedHClk: NetSchedHClkWatchdogSysWorld:4602: vmnic1: packets completion seems stuck, issuing reset 2018-06-24T03:14:09.310Z cpu0:65596)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:09.499Z cpu0:65940)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:09.499Z cpu0:65940)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:10.109Z cpu7:103063)HBX: 2958: 'FN_TMP01': HB at offset 3473408 - Waiting for timed out HB: 2018-06-24T03:14:10.109Z cpu7:103063) [HB state abcdef02 offset 3473408 gen 19 stampUS 96653456148 uuid 5b2d8e09-3d404882-af51-001b21bdc930 jrnl <FB 7> drv 24.81 lockImpl 4 ip 192.168.0.10] 2018-06-24T03:14:10.500Z cpu2:65943)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:10.500Z cpu2:65943)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:10.704Z cpu0:66306)HBX: 2958: 'FN_TMP01': HB at offset 3473408 - Waiting for timed out HB: 2018-06-24T03:14:10.704Z cpu0:66306) [HB state abcdef02 offset 3473408 gen 19 stampUS 96653456148 uuid 5b2d8e09-3d404882-af51-001b21bdc930 jrnl <FB 7> drv 24.81 lockImpl 4 ip 192.168.0.10] 2018-06-24T03:14:11.120Z cpu0:67666)HBX: 2958: 'FN_TMP01': HB at offset 3473408 - Waiting for timed out HB: 2018-06-24T03:14:11.120Z cpu0:67666) [HB state abcdef02 offset 3473408 gen 19 stampUS 96653456148 uuid 5b2d8e09-3d404882-af51-001b21bdc930 jrnl <FB 7> drv 24.81 lockImpl 4 ip 192.168.0.10] 2018-06-24T03:14:11.502Z cpu6:65934)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:11.502Z cpu6:65934)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:12.503Z cpu2:65930)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:12.504Z cpu2:65930)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:13.506Z cpu0:65940)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:13.506Z cpu0:65940)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds 2018-06-24T03:14:14.506Z cpu3:65943)WARNING: LinNet: netdev_watchdog:3688: NETDEV WATCHDOG: vmnic1: transmit timed out 2018-06-24T03:14:14.506Z cpu3:65943)<6>ixgbe 0000:02:00.0: vmnic1: Fake Tx hang detected with timeout of 160 seconds
What I have tried:
- I have tried tunables from the 10GB primer and several other post
- Jumbo Frames (I got less performance when enable)
- Disable ACK in ESXi
- Update ESXi 6.5 to U2
- All devices are setup to Round-Robin policy with 1 iops
- Send email to 10Gtek support
- VDS and standard switches
- https://forums.freenas.org/index.php?threads/10-gig-networking-primer.25749/
- https://forums.freenas.org/index.php?threads/zvol-recommended-block-size.24558/
- https://forums.freenas.org/index.ph...hen-single-path-for-writes.22475/#post-150037
- https://forums.freenas.org/index.php?threads/10gb-a-bit-slow-optimization-tips.64022/
- https://forums.freenas.org/index.ph...nalyzer-workers-any-tuning-suggestions.62762/
- https://forums.freenas.org/index.php?threads/x520-speed-issue.43695/
- https://forums.freenas.org/index.ph...e-errors-coming-from-freenas-9-10-2-u6.62738/
- https://www.virten.net/vmware/esxi-...2&plugin=0&sensekey=e&asc=1d&ascq=0&opcode=24 <-- interesting - VMware ESXi SCSI Sense Code Decoder
- https://forums.freenas.org/index.php?threads/nfs-performance-numbers-i-need-more-speed.30499/
- https://forums.freenas.org/index.ph...-is-accurate-lun-rpm-setting-in-extent.30878/
- Is this might be a hardware issue? (NICs or cable)
- Is there any tuning that I'm missing? When tried tunables it got worse
- Could the CPU on the ESXi box could be a bottleneck for the 10gb?
- Could be my choice of NICs (both the NetApp Chelsio and the 10Gtek) is wrong? perhaps another model?
- Does anyone have a similar setup in terms of 10GB connections that can shine some light?
EDIT 2: Disk Model
