Thank you for replies.
Here are exception details when I click on Import Volume.
Please let me know if there is anything I can try.
ValueError at /storage/import/
invalid literal for float(): 0.1a
Request Method: GET
Request URL:
https://192.168.1.1:8181/storage/import/
Django Version: 1.3.1
Exception Type: ValueError
Exception Value:
Exception Location: /usr/local/www/freenasUI/storage/forms.py in <lambda>, line 441
Python Executable: /usr/local/bin/python
Python Version: 2.7.2
Python Path: ['/usr/local/www/freenasUI', '/usr/local/lib/python2.7/site-packages/setuptools-0.6c11-py2.7.egg', '/usr/local/lib/python2.7/site-packages/South-0.7.3-py2.7.egg', '/usr/local/lib/python2.7/site-packages/pyasn1-0.0.13b-py2.7.egg', '/usr/local/lib/python2.7/site-packages/pyasn1_modules-0.0.1a-py2.7.egg', '/usr/local/lib/python2.7/site-packages/flup-1.0.2-py2.7.egg', '/usr/local/lib/python2.7/site-packages/python_ldap-2.4.1-py2.7-freebsd-8.2-STABLE-amd64.egg', '/usr/local/lib/python27.zip', '/usr/local/lib/python2.7', '/usr/local/lib/python2.7/plat-freebsd8', '/usr/local/lib/python2.7/lib-tk', '/usr/local/lib/python2.7/lib-old', '/usr/local/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/site-packages', '/usr/local/www', '/usr/local/www', '/usr/local/www/freenasUI']
Server time: Fri, 14 Oct 2011 13:33:31 -0700
Traceback Switch to copy-and-paste view
/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py in get_response
resolver = urlresolvers.RegexURLResolver(r'^/', urlconf)
callback, callback_args, callback_kwargs = resolver.resolve(
request.path_info)
# Apply view middleware
for middleware_method in self._view_middleware:
response = middleware_method(request, callback, callback_args, callback_kwargs) ...
if response:
break
if response is None:
try:
response = callback(request, *callback_args, **callback_kwargs)
▶ Local vars
Variable Value
exceptions
u'<module 'django.core.exceptions' from '/usr/local/lib/python2.7/site-packages/django/core/exceptions.pyc'>'
callback_args
u'()'
receivers
u'[(<function _rollback_on_exception at 0x80349b488>, None)]'
middleware_method
u'<bound method RequireLoginMiddleware.process_view of <freenasUI.freeadmin.middleware.RequireLoginMiddleware object at 0x804d2a510>>'
self
u'<django.core.handlers.wsgi.WSGIHandler object at 0x804d1b310>'
settings
u'<django.conf.LazySettings object at 0x8021a5410>'
request
u'<WSGIRequest\nGET:<QueryDict: {}>,\nPOST:<QueryDict: {}>,\nCOOKIES:{'__utma': '132462155.10415900.1316747961.1316756378.1317931864.3',\n '__utmz': '132462155.1316747961.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)',\n 'csrftoken': 'ed0412e11db045bbbe9ed797911ff5bf',\n 'mytreeSaveStateCookie': 'root%2C48%2C12%2C41',\n 'sessionid': '90c3132d8ca7e48b9f180f9fd39299a4'},\nMETA:{'CONTENT_TYPE': 'application/x-www-form-urlencoded',\n 'DOCUMENT_ROOT': '/usr/local/www/data/',\n 'GATEWAY_INTERFACE': 'CGI/1.1',\n 'HTTPS': 'on',\n 'HTTP_ACCEPT': '*/*',\n 'HTTP_ACCEPT_ENCODING': 'gzip, deflate',\n 'HTTP_ACCEPT_LANGUAGE': 'en-us',\n 'HTTP_CONNECTION': 'keep-alive',\n 'HTTP_COOKIE': 'mytreeSaveStateCookie=root%2C48%2C12%2C41; sessionid=90c3132d8ca7e48b9f180f9fd39299a4; csrftoken=ed0412e11db045bbbe9ed797911ff5bf; __utma=132462155.10415900.1316747961.1316756378.1317931864.3; __utmz=132462155.1316747961.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)',\n 'HTTP_HOST': '192.168.1.1:8181',\n 'HTTP_REFERER': 'https://192.168.1.1:8181/',\n 'HTTP_USER_AGENT': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_2) AppleWebKit/534.51.22 (KHTML, like Gecko) Version/5.1.1 Safari/534.51.22',\n 'HTTP_X_CSRFTOKEN': 'ed0412e11db045bbbe9ed797911ff5bf',\n 'HTTP_X_REQUESTED_WITH': 'XMLHttpRequest',\n 'PATH_INFO': u'/storage/import/',\n 'PATH_TRANSLATED': '/usr/local/www/data//storage/import/',\n 'QUERY_STRING': '',\n 'REDIRECT_STATUS': '200',\n 'REDIRECT_URI': '/mysite.fcgi/storage/import/',\n 'REMOTE_ADDR': '38.98.0.125',\n 'REMOTE_PORT': '52810',\n 'REQUEST_METHOD': 'GET',\n 'REQUEST_URI': '/storage/import/',\n 'SCRIPT_FILENAME': '/usr/local/www/data/mysite.fcgi',\n 'SCRIPT_NAME': u'',\n 'SERVER_ADDR': '192.168.1.150',\n 'SERVER_NAME': '192.168.1.1',\n 'SERVER_PORT': '8181',\n 'SERVER_PROTOCOL': 'HTTP/1.1',\n 'SERVER_SOFTWARE': 'lighttpd/1.4.29',\n 'wsgi.errors': <flup.server.fcgi_base.TeeOutputStream object at 0x80a2cc450>,\n 'wsgi.input': <flup.server.fcgi_base.InputStream object at 0x80779d590>,\n 'wsgi.multiprocess': False,\n 'wsgi.multithread': True,\n 'wsgi.run_once': False,\n 'wsgi.url_scheme': 'https',\n 'wsgi.version': (1, 0)}>'
callback
u'<function volimport at 0x8072b3e60>'
resolver
u'<RegexURLResolver freenasUI.urls (None:None) ^/>'
urlresolvers
u'<module 'django.core.urlresolvers' from '/usr/local/lib/python2.7/site-packages/django/core/urlresolvers.pyc'>'
callback_kwargs
u'{}'
response
u'None'
urlconf
u''freenasUI.urls''
/usr/local/www/freenasUI/freeadmin/middleware.py in process_view
backend = get_backends()[0]
user.backend = "%s.%s" % (backend.__module__, backend.__class__.__name__)
login(request, user)
if request.path == settings.LOGIN_URL:
return None
if hasattr(view_func, '__is_public'):
return None
return login_required(view_func)(request,*view_args,**view_kwargs) ...
class LocaleMiddleware(object):
def process_request(self, request):
if request.method == 'GET' and 'lang' in request.GET:
language = request.GET['lang']
▶ Local vars
Variable Value
view_kwargs
u'{}'
view_args
u'()'
self
u'<freenasUI.freeadmin.middleware.RequireLoginMiddleware object at 0x804d2a510>'
request
view_func
/usr/local/lib/python2.7/site-packages/django/contrib/auth/decorators.py in _wrapped_view
that takes the user object and returns True if the user passes.
def decorator(view_func):
@wraps(view_func, assigned=available_attrs(view_func))
def _wrapped_view(request, *args, **kwargs):
if test_func(request.user):
return view_func(request, *args, **kwargs) ...
path = request.build_absolute_uri()
# If the login url is the same scheme and net location then just
# use the path as the "next" url.
login_scheme, login_netloc = urlparse.urlparse(login_url or
settings.LOGIN_URL)[:2]
current_scheme, current_netloc = urlparse.urlparse(path)[:2]
▶ Local vars
Variable Value
test_func
u'<function <lambda> at 0x80a2db230>'
login_url
u'None'
args
u'()'
request
kwargs
u'{}'
redirect_field_name
u''next''
view_func
/usr/local/www/freenasUI/storage/views.py in volimport
else:
if 'volume_disks' in request.POST:
disks = request.POST.getlist('volume_disks')
else:
disks = None
else:
form = forms.VolumeImportForm() ...
disks = []
return render(request, 'storage/import.html', {
'form': form,
'disks': disks
▶ Local vars
Variable Value
request
/usr/local/www/freenasUI/storage/forms.py in __init__
volume_name = forms.CharField(max_length = 30, label = _('Volume name') )
volume_disks = forms.ChoiceField(choices=(), widget=forms.Select(attrs=attrs_dict), label = _('Member disk'))
volume_fstype = forms.ChoiceField(choices = ((x, x) for x in ('UFS', 'NTFS', 'MSDOSFS', 'EXT2FS')), widget=forms.RadioSelect(attrs=attrs_dict), label = 'File System type')
def __init__(self, *args, **kwargs):
super(VolumeImportForm, self).__init__(*args, **kwargs)
self.fields['volume_disks'].choices = self._populate_disk_choices() ...
self.fields['volume_disks'].choices.sort(key = lambda a : float(re.sub(r'^.*?([0-9]+)[^0-9]*', r'\1.',a[0])))
def _populate_disk_choices(self):
diskchoices = dict()
n = notifier()
▶ Local vars
Variable Value
self
u'<freenasUI.storage.forms.VolumeImportForm object at 0x80a2cc290>'
args
u'()'
kwargs
u'{}'
/usr/local/www/freenasUI/storage/forms.py in _populate_disk_choices
rootdev_base = re.search('[a-z/]*[0-9]*', rootdev)
if rootdev_base != None:
for part in diskchoices.keys():
if part.startswith(rootdev_base.group(0)):
del diskchoices[part]
choices = diskchoices.items()
choices.sort(key = lambda a : float(re.sub(r'^.*?([0-9]+)[^0-9]*', r'\1.',a[0]))) ...
return choices
def clean(self):
cleaned_data = self.cleaned_data
volume_name = cleaned_data.get("volume_name")
if models.Volume.objects.filter(vol_name = volume_name).count() > 0:
▶ Local vars
Variable Value
used_disks
u'['ada1', 'ada2', 'ada3']'
capacity
u''21.2 MB''
diskchoices
u'{'ada0s1a': 'ada0s1a (988.3 MB)',\n 'ada0s2': 'ada0s2 (988.3 MB)',\n 'ada0s3': 'ada0s3 (1.5 MB)',\n 'ada0s4': 'ada0s4 (21.2 MB)',\n 'ada4p1': 'ada4p1 (2.1 GB)',\n 'ada4p2': 'ada4p2 (998.1 GB)'}'
i
u''ada3''
self
devname
u''ada0s4''
parts
u'{'/dev/ada0s1a': {'capacity': '988283392', 'devname': 'ada0s1a'},\n '/dev/ada0s2': {'capacity': '988291584', 'devname': 'ada0s2'},\n '/dev/ada0s3': {'capacity': '1548288', 'devname': 'ada0s3'},\n '/dev/ada0s4': {'capacity': '21159936', 'devname': 'ada0s4'},\n '/dev/ada4p1': {'capacity': '2147483648', 'devname': 'ada4p1'},\n '/dev/ada4p2': {'capacity': '998057319936', 'devname': 'ada4p2'},\n '/dev/da0s1a': {'capacity': '988283392', 'devname': 'da0s1a'},\n '/dev/da0s2': {'capacity': '988291584', 'devname': 'da0s2'},\n '/dev/da0s3': {'capacity': '1548288', 'devname': 'da0s3'},\n '/dev/da0s4': {'capacity': '21159936', 'devname': 'da0s4'}}'
choices
u'[('ada4p2', 'ada4p2 (998.1 GB)'),\n ('ada4p1', 'ada4p1 (2.1 GB)'),\n ('ada0s3', 'ada0s3 (1.5 MB)'),\n ('ada0s2', 'ada0s2 (988.3 MB)'),\n ('ada0s4', 'ada0s4 (21.2 MB)'),\n ('ada0s1a', 'ada0s1a (988.3 MB)')]'
rootdev
u''da0s1a''
part
u''da0s1a''
n
u'<freenasUI.middleware.notifier.notifier instance at 0x80a2d7200>'
rootdev_base
u'<_sre.SRE_Match object at 0x8072282a0>'
return choices
def clean(self):
▶ Local vars
Variable Value
a
u'('ada0s1a', 'ada0s1a (988.3 MB)')'
Request information
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
csrftoken
__utma
sessionid
__utmz
META
Variable Value
wsgi.multiprocess
False
HTTP_REFERER
REDIRECT_STATUS
'200'
SERVER_SOFTWARE
'lighttpd/1.4.29'
SCRIPT_NAME
u''
HTTP_X_CSRFTOKEN
REQUEST_METHOD
'GET'
PATH_INFO
u'/storage/import/'
SERVER_PROTOCOL
'HTTP/1.1'
QUERY_STRING
HTTP_USER_AGENT
HTTP_CONNECTION
'keep-alive'
HTTP_COOKIE
SERVER_NAME
'192.168.1.1'
REMOTE_PORT
'52810'
wsgi.url_scheme
'https'
PATH_TRANSLATED
SERVER_PORT
'8181'
SERVER_ADDR
'192.168.1.150'
DOCUMENT_ROOT
'XMLHttpRequest'
SCRIPT_FILENAME
wsgi.input
HTTP_HOST
'192.168.1.1:8181'
HTTPS
'on'
wsgi.multithread
True
REQUEST_URI
'/storage/import/'
HTTP_ACCEPT
wsgi.version
(1, 0)
GATEWAY_INTERFACE
'CGI/1.1'
wsgi.run_once
False
wsgi.errors
REMOTE_ADDR
'38.98.0.125'
'en-us'
REDIRECT_URI
CONTENT_TYPE
'gzip, deflate'
Settings
Using settings module freenasUI.settings
Setting Value
YEAR_MONTH_FORMAT
'F Y'
USE_L10N
True
USE_THOUSAND_SEPARATOR
False
LANGUAGE_CODE
'en-us'
ROOT_URLCONF
'freenasUI.urls'
MANAGERS
(('iXsystems, Inc.', 'freenas@ixsystems.com'),)
DOJANGO_DATAGRID_ACCESS
('account', 'system', 'network', 'storage', 'sharing', 'services')
DEFAULT_CHARSET
'utf-8'
STATIC_ROOT
'/usr/local/www/freenasUI/static'
DOJANGO_DOJO_VERSION
'1.6.1'
MESSAGE_STORAGE
'django.contrib.messages.storage.user_messages.LegacyFallbackStorage'
DATABASE_HOST
IGNORABLE_404_STARTS
('/cgi-bin/', '/_vti_bin', '/_vti_inf')
SEND_BROKEN_LINK_EMAILS
False
URL_VALIDATOR_USER_AGENT
'Django/1.3.1 (
http://www.djangoproject.com)'
STATICFILES_FINDERS
('django.contrib.staticfiles.finders.FileSystemFinder', 'django.contrib.staticfiles.finders.AppDirectoriesFinder')
SESSION_COOKIE_DOMAIN
None
SESSION_COOKIE_NAME
'sessionid'
COMMENTS_MODERATORS_GROUP
None
TIME_INPUT_FORMATS
('%H:%M:%S', '%H:%M', '%Y-%m-%dT%H:%M', '%Y-%m-%dT%H:%M:%S', 'T%H:%M:%S', 'T%H:%M')
DATABASES
{'default': {'ENGINE': 'django.db.backends.sqlite3', 'HOST': '', 'NAME': '/data/freenas-v1.db', 'OPTIONS': {}, 'PASSWORD': '********************', 'PORT': '', 'TEST_CHARSET': None, 'TEST_COLLATION': None, 'TEST_MIRROR': None, 'TEST_NAME': '/usr/local/www/freenasUI/test.db', 'TIME_ZONE': None, 'USER': ''}}
TEST_DATABASE_NAME
None
FILE_UPLOAD_PERMISSIONS
None
FILE_UPLOAD_HANDLERS
('django.core.files.uploadhandler.MemoryFileUploadHandler', 'django.core.files.uploadhandler.TemporaryFileUploadHandler')
DEFAULT_CONTENT_TYPE
'text/html'
APPEND_SLASH
True
FIRST_DAY_OF_WEEK
0
DATABASE_ROUTERS
DOJANGO_DOJO_PROFILE
'local_release'
STATICFILES_STORAGE
'django.contrib.staticfiles.storage.StaticFilesStorage'
CACHES
{'default': {'BACKEND': 'django.core.cache.backends.locmem.LocMemCache', 'LOCATION': ''}}
SERVER_EMAIL
'root@localhost'
SESSION_COOKIE_PATH
USE_X_FORWARDED_HOST
False
IGNORABLE_404_ENDS
('mail.pl', 'mailform.pl', 'mail.cgi', 'mailform.cgi', 'favicon.ico', '.php')
MIDDLEWARE_CLASSES
('django.middleware.common.CommonMiddleware', 'django.contrib.sessions.middleware.SessionMiddleware', 'freenasUI.freeadmin.middleware.LocaleMiddleware', 'django.contrib.auth.middleware.AuthenticationMiddleware', 'freenasUI.freeadmin.middleware.RequireLoginMiddleware', 'django.middleware.csrf.CsrfViewMiddleware', 'dojango.middleware.DojoCollector')
USE_I18N
True
THOUSAND_SEPARATOR
SECRET_KEY
LANGUAGE_COOKIE_NAME
'django_language'
FILE_UPLOAD_TEMP_DIR
'/var/tmp/firmware/'
TRANSACTIONS_MANAGED
False
LOGGING_CONFIG
'django.utils.log.dictConfig'
SESSION_COOKIE_AGE
1209600
TEMPLATE_LOADERS
('django.template.loaders.filesystem.Loader', 'django.template.loaders.app_directories.Loader')
TEMPLATE_DEBUG
False
AUTHENTICATION_BACKENDS
('django.contrib.auth.backends.ModelBackend',)
TEST_DATABASE_COLLATION
None
FORCE_SCRIPT_NAME
CACHE_BACKEND
'locmem://'
SESSION_COOKIE_SECURE
False
CSRF_COOKIE_DOMAIN
None
FILE_CHARSET
'utf-8'
DEBUG
False
SESSION_FILE_PATH
None
DEFAULT_FILE_STORAGE
'django.core.files.storage.FileSystemStorage'
INSTALLED_APPS
['django.contrib.auth', 'django.contrib.contenttypes', 'django.contrib.sessions', 'django.contrib.staticfiles', 'freeadmin', 'south', 'dojango', 'account', 'system', 'network', 'storage', 'sharing', 'services']
LANGUAGES
(('ar', 'Arabic'), ('az', 'Azerbaijani'), ('bg', 'Bulgarian'), ('bn', 'Bengali'), ('bs', 'Bosnian'), ('ca', 'Catalan'), ('cs', 'Czech'), ('cy', 'Welsh'), ('da', 'Danish'), ('de', 'German'), ('el', 'Greek'), ('en', 'English'), ('en-gb', 'British English'), ('es', 'Spanish'), ('es-ar', 'Argentinian Spanish'), ('es-mx', 'Mexican Spanish'), ('es-ni', 'Nicaraguan Spanish'), ('et', 'Estonian'), ('eu', 'Basque'), ('fa', 'Persian'), ('fi', 'Finnish'), ('fr', 'French'), ('fy-nl', 'Frisian'), ('ga', 'Irish'), ('gl', 'Galician'), ('he', 'Hebrew'), ('hi', 'Hindi'), ('hr', 'Croatian'), ('hu', 'Hungarian'), ('id', 'Indonesian'), ('is', 'Icelandic'), ('it', 'Italian'), ('ja', 'Japanese'), ('ka', 'Georgian'), ('km', 'Khmer'), ('kn', 'Kannada'), ('ko', 'Korean'), ('lt', 'Lithuanian'), ('lv', 'Latvian'), ('mk', 'Macedonian'), ('ml', 'Malayalam'), ('mn', 'Mongolian'), ('nl', 'Dutch'), ('no', 'Norwegian'), ('nb', 'Norwegian Bokmal'), ('nn', 'Norwegian Nynorsk'), ('pa', 'Punjabi'), ('pl', 'Polish'), ('pt', 'Portuguese'), ('pt-br', 'Brazilian Portuguese'), ('ro', 'Romanian'), ('ru', 'Russian'), ('sk', 'Slovak'), ('sl', 'Slovenian'), ('sq', 'Albanian'), ('sr', 'Serbian'), ('sr-latn', 'Serbian Latin'), ('sv', 'Swedish'), ('ta', 'Tamil'), ('te', 'Telugu'), ('th', 'Thai'), ('tr', 'Turkish'), ('uk', 'Ukrainian'), ('ur', 'Urdu'), ('vi', 'Vietnamese'), ('zh-cn', 'Simplified Chinese'), ('zh-tw', 'Traditional Chinese'))
DATABASE_ENGINE
BLACKLIST_NAV
('django.contrib.auth', 'django.contrib.contenttypes', 'django.contrib.sessions', 'django.contrib.staticfiles', 'south', 'dojango', 'freeadmin')
DATABASE_NAME
COMMENTS_FIRST_FEW
0
PREPEND_WWW
False
TEST_DATABASE_CHARSET
None
SESSION_COOKIE_HTTPONLY
False
DATABASE_PORT
DEBUG_PROPAGATE_EXCEPTIONS
False
MONTH_DAY_FORMAT
'F j'
LOGIN_URL
'/account/login/'
SESSION_EXPIRE_AT_BROWSER_CLOSE
False
TIME_FORMAT
'P'
DATE_INPUT_FORMATS
('%Y-%m-%d', '%m/%d/%Y', '%m/%d/%y', '%b %d %Y', '%b %d, %Y', '%d %b %Y', '%d %b, %Y', '%B %d %Y', '%B %d, %Y', '%d %B %Y', '%d %B, %Y', '%Y-%m-%dT%H:%M', '%Y-%m-%dT%H:%M:%S')
CSRF_COOKIE_NAME
'csrftoken'
EMAIL_HOST_PASSWORD
PASSWORD_RESET_TIMEOUT_DAYS
CACHE_MIDDLEWARE_ALIAS
'default'
SESSION_SAVE_EVERY_REQUEST
False
ADMIN_MEDIA_PREFIX
'/static/admin/'
NUMBER_GROUPING
0
SESSION_ENGINE
'django.contrib.sessions.backends.file'
CSRF_FAILURE_VIEW
'django.views.csrf.csrf_failure'
COMMENTS_SKETCHY_USERS_GROUP
None
LOGIN_REDIRECT_URL
LOGGING
{'disable_existing_loggers': False, 'handlers': {'mail_admins': {'class': 'django.utils.log.AdminEmailHandler', 'level': 'ERROR'}}, 'loggers': {'django.request': {'handlers': ['mail_admins'], 'level': 'ERROR', 'propagate': True}}, 'version': 1}
CACHE_MIDDLEWARE_KEY_PREFIX
LOCALE_PATHS
('/usr/local/www/freenasUI/locale',)
HERE
COMMENTS_ALLOW_PROFANITIES
False
LOGOUT_URL
'/account/logout/'
EMAIL_USE_TLS
False
TEMPLATE_DIRS
('/usr/local/www/freenasUI/templates',)
FIXTURE_DIRS
EMAIL_HOST
'localhost'
DATE_FORMAT
'N j, Y'
MEDIA_ROOT
'/usr/local/www/freenasUI/media'
ADMINS
FORMAT_MODULE_PATH
None
DEFAULT_FROM_EMAIL
'webmaster@localhost'
STATICFILES_DIRS
('/usr/local/www/freenasUI/media',)
MEDIA_URL
'/media/'
DATETIME_FORMAT
'N j, Y, P'
EMAIL_SUBJECT_PREFIX
'[Django] '
SITE_ID
DISALLOWED_USER_AGENTS
ALLOWED_INCLUDE_ROOTS
DECIMAL_SEPARATOR
SHORT_DATE_FORMAT
'm/d/Y'
DATABASE_USER
TEST_RUNNER
'django.test.simple.DjangoTestSuiteRunner'
TIME_ZONE
None
FILE_UPLOAD_MAX_MEMORY_SIZE
268435456
EMAIL_BACKEND
'django.core.mail.backends.smtp.EmailBackend'
DEFAULT_TABLESPACE
TEMPLATE_CONTEXT_PROCESSORS
('django.core.context_processors.request', 'django.contrib.auth.context_processors.auth', 'django.core.context_processors.i18n', 'django.core.context_processors.media', 'django.core.context_processors.static', 'dojango.context_processors.config')
DOJANGO_DOJO_DEBUG
True
SETTINGS_MODULE
'freenasUI.settings'
USE_ETAGS
False
LANGUAGES_BIDI
('he', 'ar', 'fa')
DEFAULT_INDEX_TABLESPACE
INTERNAL_IPS
STATIC_URL
'/media/'
EMAIL_PORT
25
SHORT_DATETIME_FORMAT
'm/d/Y P'
ABSOLUTE_URL_OVERRIDES
DATABASE_OPTIONS
CACHE_MIDDLEWARE_SECONDS
600
BANNED_IPS
TEMPLATE_STRING_IF_INVALID
DATETIME_INPUT_FORMATS
('%Y-%m-%d %H:%M:%S', '%Y-%m-%d %H:%M', '%Y-%m-%d', '%m/%d/%Y %H:%M:%S', '%m/%d/%Y %H:%M', '%m/%d/%Y', '%m/%d/%y %H:%M:%S', '%m/%d/%y %H:%M', '%m/%d/%y')
DATABASE_PASSWORD
ADMIN_FOR
PROFANITIES_LIST
EMAIL_HOST_USER
COMMENTS_BANNED_USERS_GROUP
None
You're seeing this error because you have DEBUG = True in your Django settings file. Change that to False, and Django will display a standard 500 page
