huseyinozsut
- Jul 12, 2021
I nearly solved all my problems. I created a VM for HAOS. Inside HAOS I installed Motioneye. So my truenas server is also my Homeassistant host and my ip cam recorder. Then I managed to install KODI in another VM, and that VM has it's own GPU. So my truenas server is also my mediacenter and iptv center.
Now I wanted to add a 2.5gbit nic. When using Truenas Core, I used my Realtek 8125 nics with adding two parameters to tunables. So I thought, on Truenas Scale, there won't be any problem. But as allways, there is.
The problem is:
When I add the second nic, it does not show up on GUI. It shows up on lspci command output. When I disable the onboard nic and connect my ethernet cable (which is going to my router) to 8125 nic works normally. So I think this is not a driver issue.
I am so close to achieve all of my goals. So if you can help me, I'll be more than happy.
I know that Realtek and 8125 is not good. But I was able to use it in truenas core and that was enough for me. Finding another 2.5gbit nic would be very hard in my country.
My onboard nic is a qualcomm atheros by the way.
The problem is:
