Problème désinstallation Machine virtuelle
undecesjours
Bonjour,
J'ai voulu désinstaller proprement une VM à partir du menu Truenas et je me retrouve avec le message d'erreur suivant, ce n'est pas très grave, mais j'aime bien une config propre. Vous avez une idée ? Je précise que je n'ai pas touché au Dataset.
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 853, in do_delete
subprocess.run(
File "/usr/local/lib/python3.8/subprocess.py", line 512, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['zfs', 'destroy', 'Raid5_1T/PI_Hole/PI_Hole-mfwnyh']' returned non-zero exit status 1.
File "/usr/local/lib/python3.8/concurrent/futures/process.py", line 239, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 91, in main_worker
res = MIDDLEWARE._run(*call_args)
File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 45, in _run
return self._call(name, serviceobj, methodobj, args, job=job)
File "/usr/local/lib/python3.8/site-packages/middlewared/worker.py", line 39, in _call
return methodobj(*params)
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/zfs.py", line 865, in do_delete
raise CallError(f'Failed to delete dataset: {error}', errno_)
middlewared.service_exception.CallError: [EFAULT] Failed to delete dataset: cannot open 'Raid5_1T/PI_Hole/PI_Hole-mfwnyh': dataset does not exist
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1195, in _call
File "/usr/local/lib/python3.8/site-packages/middlewared/service.py", line 471, in delete
rv = await self.middleware._call(
File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 973, in nf
File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/vm.py", line 1537, in do_delete
await self.middleware.call('zfs.dataset.delete', disk_name)
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1238, in call
return await self._call(
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1203, in _call
return await self._call_worker(name, *prepared_call.args)
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1209, in _call_worker
return await self.run_in_proc(main_worker, name, args, job)
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1136, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
Vous pouvez essayer zfs create Raid5_1T/PI_Hole/PI_Hole-mfwnyh
