Salut à tous, je viens d'acheter deux disques SSD identiques pour mon boot sur TrueNas Core. J'ai installé TrueNas sur l'un, ensuite j'essai de mettre le second avec la fonction attach sans succes.
J'ai beau chercher, je vois pas pourquoi. Les disques fonctionnent parfaitement. J'ai testé le deuxième qui ne veut pas être attaché, et pas de problème.
Merci pour votre aide.
			Attach Device
Error: [EFAULT] concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 220, in extend i['target'].attach(newvdev) File "libzfs.pyx", line 402, in libzfs.ZFS.__exit__ File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 220, in extend i['target'].attach(newvdev) File "libzfs.pyx", line 2117, in libzfs.ZFSVdev.attach libzfs.ZFSException: can only attach to mirrors and top-level disks During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/concurrent/futures/process.py", line 246, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 111, in main_worker res = MIDDLEWARE._run(*call_args) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 45, in _run return self._call(name, serviceobj, methodobj, args, job=job) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/local/lib/python3.9/site-packages/middlewared/worker.py", line 39, in _call return methodobj(*params) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 985, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/zfs.py", line 223, in extend raise CallError(str(e), e.code) middlewared.service_exception.CallError: [EZFS_BADTARGET] can only attach to mirrors and top-level disks """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 386, in __run_body rv = await self.middleware._call_worker(self.method_name, *self.args, job={'id': self.id}) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1250, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1169, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1152, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) middlewared.service_exception.CallError: [EZFS_BADTARGET] can only attach to mirrors and top-level disksJ'ai beau chercher, je vois pas pourquoi. Les disques fonctionnent parfaitement. J'ai testé le deuxième qui ne veut pas être attaché, et pas de problème.
