Powershield Defender 1200 UPS Communication Issues
SLIMaxPower
So I am running 9.3 with system updates done.
I am having communication issues. The UPS gets dropped after a couple of minutes.
I have replaced the cable.
I emailed the supplier who advised me to use the following details.
driver = blazer_usb
subdriver = cypress
port = auto
vendorid = 0665
productid = 5161
protocol = mustek
Welcome to FreeNAS
[root@hpserver] ~# upsc ups@localhost
battery.charge: 100
battery.voltage: 27.60
battery.voltage.high: 26.00
battery.voltage.low: 20.80
battery.voltage.nominal: 24.0
device.type: ups
driver.name: blazer_usb
driver.parameter.pollinterval: 2
driver.parameter.port: auto
driver.parameter.productid: 5161
driver.parameter.protocol: mustek
driver.parameter.subdriver: cypress
driver.parameter.vendorid: 0665
driver.version: 2.7.2
driver.version.internal: 0.11
input.current.nominal: 5.0
input.frequency: 50.1
input.frequency.nominal: 50
input.voltage: 250.4
input.voltage.fault: 250.4
input.voltage.nominal: 240
output.voltage: 250.4
ups.beeper.status: enabled
ups.delay.shutdown: 30
ups.delay.start: 180
ups.load: 5
ups.productid: 5161
ups.status: OL
ups.type: offline / line interactive
ups.vendorid: 0665
[root@hpserver] ~#
SLIMaxPower
Feb 28 11:45:07 hpserver upsmon[17935]: UPS ups is unavailable
Feb 28 11:45:12 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:17 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:22 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:27 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:32 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:37 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:42 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:47 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:52 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:45:57 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:02 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:07 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:12 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:17 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:22 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:27 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:32 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:37 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:42 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:47 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:52 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:46:57 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:02 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:07 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:12 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:17 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:22 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:27 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:32 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:37 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:42 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:47 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:52 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:47:57 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:02 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:07 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:12 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:17 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:22 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:27 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:32 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:37 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:42 hpserver upsmon[17935]: Poll UPS [ups] failed - Driver not connected
Feb 28 11:48:44 hpserver upsd[17913]: Can't connect to UPS [ups] (blazer_usb-ups): No such file or directory
I realise this is an old thread. Did you ever get this resolved? The Defender 1200 appears to be the only Australian built NUT compatible UPS.
