dAlexis
- Aug 15, 2015
Device named Irbis, but I do not find a trap of it's real Chinese OEM name :( Looks OK, however, cleas sin signal, good work time. USB present, in Windows well monitored by UPSmart software (ver 1.5). Linux software provided, but not tested (seems linux version of UPSmart too, as I understand)
However, in BSD this (self-censored) device looks highly mysterious. dmesg gives this:
ugen0.4: <vendor 0x0001 MEC0003> at usbus0 - WHAT!???
After digging in Internet I found, that MEC0003 is a UPS protocol, and it's supported by blazer driver. UPS was found by the driver, however, info about it looks, hm... completely wrong - battery voltage negative, etc. Please, point me 2 place, where correct settings 4 blazer driver may be found. Any advice welcome! Seems 2 me, that it may be solved by correct parameters, but how 2 find them - no mind... Ready to various tricks, such as USB trace attempt in Windows (not sure, that it'll be successful, but I'll try )
root@freenas:~ # upsc ups battery.voltage: 0.00 battery.voltage.high: -1.08 battery.voltage.low: -0.87 device.type: ups driver.name: blazer_usb driver.parameter.pollinterval: 2 driver.parameter.port: /dev/ugen0.4 driver.parameter.synchronous: no driver.version: 2.7.4 driver.version.internal: 0.12 input.frequency: 0.0 input.voltage: 0.0 input.voltage.fault: 0.0 output.voltage: 0.0 ups.beeper.status: disabled ups.delay.shutdown: 30 ups.delay.start: 180 ups.load: 0 ups.productid: 0000 ups.status: OL ups.temperature: 0.0 ups.type: online ups.vendorid: 0001 root@freenas:~ #
