Hi folks,
I'm building a 10 drive config (8 HDDs, 2 SSDs for boot) and looking for PSU & cabling advice.
Case: Fractal Design Node 804
MB: Supermicro X11SSL-CF
CPU: Intel Xeon E3-1220 V6 Kaby Lake 3.0 GHz LGA 1151 72W
RAM: 2x SAMSUNG 16GB 288-Pin DDR4 SDRAM ECC 2133 (PC4 17000)
SSD: 2x Intel SSD Enterprise Edition 710 Series 100GB 2.5 SATA II
Drives: 8x HGST 8TB 12Gb/s SAS
PSU: Considering EVGA SuperNOVA 750 G1+
My initial concern: There aren't nearly enough SATA ports on the PSU and there's a warning in the Freenas hardware guidance not to split them. Also, PSU specs say 120w max output on the +3.3V/+5V rails, so at ~35W/drive I'm way over that. Is there something I'm missing? How do I power all of these drives properly?
Thank you!
Thank you!
