Powercom USB UPS - usbserial module needed
secondstar
I'm running on FreeNAS 9.2 and use the Powercom IMPERIAL UPS (2009 model, with PID=0x0002). NUT can communicate with this UPS via powercom (requires 'usbserial' kernel module) driver (from compatibility list on the NUT's site).
When I connect the UPS to the USB - the FreeNAS detect it
freenas kernel: ugen0.4: <POWERCOM Co.,LTD> at usbus0
but NUT is don't start with this port (ugen0.4)
I've tried to install the Ubuntu instead of FreeNAS on my hardware, and the UPS has been detected by NUT. But Ubuntu have usbserial module which attach my UPS to /dev/ttyUSB0 device. As I understand, the FreeNAS haven't the usbserial module in the kernel.
How to add/enable usbserial.ko in FreeNAS?
wohn
Im also looking for the same answer. Ultra 1000va UPS with Powercom USB to Serial. Device ID 0002. Nut supports this communications device just need to add USBSERIAL to FreeBSD Kernel and have no idea how.
Any help would be appreciated.
D
dlavigne
Guest
Please create a report at bugs.freenas.org and post the issue number here.
