Possible failing drive?
I received this around 2AM today from FreeNAS:
> (da11:mps0:0:19:0): READ(10). CDB: 28 00 ac 18 ab 08 00 00 80 00 length 65536 SMID 994 terminated ioc 804b scsi 0 state 0 xfer 0
> (da11:mps0:0:19:0): READ(10). CDB: 28 00 ac 18 ab c8 00 00 40 00 length 32768 SMID 464 terminated ioc 804b scsi 0 state 0 xfer 0
> (da11:mps0:0:19:0): READ(10). CDB: 28 00 ac 18 e7 10 00 00 08 00 length 4096 SMID 355 terminated ioc 804b scsi 0 state 0 xfer 0
> (da11:mps0:0:19:0): READ(10). CDB: 28 00 ac 18 aa c8 00 00 40 00
> (da11:mps0:0:19:0): CAM status: SCSI Status Error
> (da11:mps0:0:19:0): SCSI status: Check Condition
> (da11:mps0:0:19:0): SCSI sense: MEDIUM ERROR asc:11,0 (Unrecovered read error)
> (da11:mps0:0:19:0): Info: 0xac18aac8
> (da11:mps0:0:19:0): Error 5, Unretryable error
-- End of security output --
I am guessing i should start the process of replacing the drive
SweetAndLow
Sweet'NASty
Probably a loose cable. What does smartctl -a /dev/da11 give you?
They're all connected via the SAS2 backplane. I'll check the smart now
Here is the output:
[root@FreeNAS] ~# smartctl -a /dev/da11
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p26 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68WT0N0
Serial Number:    WD-WCC4E0359664
LU WWN Device Id: 5 0014ee 2b3d04256
Firmware Version: 80.00A80
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Dec 14 20:04:56 2015 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (54300) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off supp             ort.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 543) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_             FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -                    60
  3 Spin_Up_Time            0x0027   175   170   021    Pre-fail  Always       -                    8233
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -                    92
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -                    0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -                    0
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -                    18237
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -                    0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -                    0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -                    92
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -                    91
193 Load_Cycle_Count        0x0032   129   129   000    Old_age   Always       -                    215331
194 Temperature_Celsius     0x0022   122   105   000    Old_age   Always       -                    30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -                    0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -                    0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -                    0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -                    0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -                    0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA             _of_first_error
# 1  Short offline       Completed without error       00%     18193         -
# 2  Short offline       Completed without error       00%     18121         -
# 3  Short offline       Completed without error       00%     18049         -
# 4  Short offline       Completed without error       00%     17979         -
# 5  Extended offline    Completed without error       00%     17940         -
# 6  Short offline       Completed without error       00%     17883         -
# 7  Short offline       Completed without error       00%     17835         -
# 8  Short offline       Completed without error       00%     17763         -
# 9  Short offline       Completed without error       00%     17691         -
#10  Short offline       Completed without error       00%     17619         -
#11  Extended offline    Completed without error       00%     17557         -
#12  Short offline       Completed without error       00%     17475         -
#13  Short offline       Completed without error       00%     17403         -
#14  Short offline       Completed without error       00%     17331         -
#15  Short offline       Completed without error       00%     17259         -
#16  Extended offline    Completed without error       00%     17221         -
#17  Short offline       Completed without error       00%     17138         -
#18  Short offline       Completed without error       00%     17090         -
#19  Short offline       Completed without error       00%     17018         -
#20  Short offline       Completed without error       00%     16947         -
#21  Short offline       Completed without error       00%     16876         -
SweetAndLow
Sweet'NASty
Smart tests are looking good but your read error rate is high and llc is high. I'm not sure if what is too high though.
is it worth RMAing? Or just picking up a second one just incase
SweetAndLow
Sweet'NASty
Rma usually only works if smart tests fail. But you can try
