panz
- May 24, 2013
dmesg
less /var/run/dmesg.boot
[root@freenas] ~# dmesg arp: 172.16.35.10 moved from 02:07:4f:00:08:0a to 0c:c4:7a:00:3b:d9 on epair0b
Copyright (c) 1992-2013 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 9.2-RELEASE-p15 #0 r262572+5b7d179: Mon Nov 17 16:27:51 PST 2014 root@build3.ixsystems.com:/tank/home/jkh/build/921/FN/os-base/amd64/fusion/j kh/921/FN/FreeBSD/src/sys/FREENAS.amd64 amd64 gcc version 4.2.1 20070831 patched [FreeBSD] CPU: Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz (3300.10-MHz K8-class CPU) Origin = "GenuineIntel" Id = 0x306a9 Family = 0x6 Model = 0x3a Stepping = 9 Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C MOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> Features2=0x7fbae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX 16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16 C,RDRAND> AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> AMD Features2=0x1<LAHF> Standard Extended Features=0x281<GSFSBASE,SMEP,ENHMOVSB> TSC: P-state invariant, performance statistics real memory = 34368126976 (32776 MB) avail memory = 33134022656 (31599 MB) Event timer "LAPIC" quality 600 /var/run/dmesg.boot...skipping... Copyright (c) 1992-2013 The FreeBSD Project. Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 The Regents of the University of California. All rights reserved. FreeBSD is a registered trademark of The FreeBSD Foundation. FreeBSD 9.2-RELEASE-p15 #0 r262572+5b7d179: Mon Nov 17 16:27:51 PST 2014 root@build3.ixsystems.com:/tank/home/jkh/build/921/FN/os-base/amd64/fusion/jkh/921/FN/FreeBSD/src/sys/FREENAS.amd64 amd64 gcc version 4.2.1 20070831 patched [FreeBSD] CPU: Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz (3300.10-MHz K8-class CPU) Origin = "GenuineIntel" Id = 0x306a9 Family = 0x6 Model = 0x3a Stepping = 9 Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> Features2=0x7fbae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND> AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> AMD Features2=0x1<LAHF> Standard Extended Features=0x281<GSFSBASE,SMEP,ENHMOVSB> TSC: P-state invariant, performance statistics real memory = 34368126976 (32776 MB) avail memory = 33134022656 (31599 MB) Event timer "LAPIC" quality 600 ACPI APIC Table: <SUPERM SMCI--MB> FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads cpu0 (BSP): APIC ID: 0 cpu1 (AP): APIC ID: 1 cpu2 (AP): APIC ID: 2 cpu3 (AP): APIC ID: 3 cpu4 (AP): APIC ID: 4 cpu5 (AP): APIC ID: 5 cpu6 (AP): APIC ID: 6 cpu7 (AP): APIC ID: 7 WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320) ioapic0 <Version 2.0> irqs 0-23 on motherboard kbd1 at kbdmux0 cryptosoft0: <software crypto> on motherboard aesni0: <AES-CBC,AES-XTS> on motherboard padlock0: No ACE support. acpi0: <SUPERM SMCI--MB> on motherboard acpi0: Power Button (fixed) acpi0: reservation of 67, 1 (4) failed cpu0: <ACPI CPU> on acpi0 cpu1: <ACPI CPU> on acpi0 cpu2: <ACPI CPU> on acpi0 cpu3: <ACPI CPU> on acpi0 cpu4: <ACPI CPU> on acpi0 cpu5: <ACPI CPU> on acpi0 cpu6: <ACPI CPU> on acpi0 cpu7: <ACPI CPU> on acpi0 hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Timecounter "HPET" frequency 14318180 Hz quality 950 Event timer "HPET" frequency 14318180 Hz quality 550 atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0 atrtc0: Warning: Couldn't map I/O. Event timer "RTC" frequency 32768 Hz quality 0 attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0 Timecounter "i8254" frequency 1193182 Hz quality 0 Event timer "i8254" frequency 1193182 Hz quality 100 Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0 pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 pci0: <ACPI PCI bus> on pcib0 pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0 pci1: <ACPI PCI bus> on pcib1 pcib2: <ACPI PCI-PCI bridge> irq 16 at device 1.1 on pci0 pci2: <ACPI PCI bus> on pcib2 mps0: <LSI SAS2008> port 0xe000-0xe0ff mem 0xdf600000-0xdf603fff,0xdf580000-0xdf5bffff irq 17 at device 0.0 on pci2 mps0: Firmware: 16.00.00.00, Driver: 16.00.00.00-fbsd mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc> em0: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0xf020-0xf03f mem 0xdf800000-0xdf81ffff,0xdf825000-0xdf825fff irq 20 at device 25.0 on pci0 em0: Using an MSI interrupt em0: Ethernet address: 0c:c4:7a:00:3b:d9 ehci0: <EHCI (generic) USB 2.0 controller> mem 0xdf824000-0xdf8243ff irq 16 at device 26.0 on pci0 usbus0: EHCI version 1.0 usbus0 on ehci0 pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0 pci3: <ACPI PCI bus> on pcib3 pcib4: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0 pci4: <ACPI PCI bus> on pcib4 em1: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0xd000-0xd01f mem 0xdf700000-0xdf71ffff,0xdf720000-0xdf723fff irq 16 at device 0.0 on pci4 em1: Using MSIX interrupts with 3 vectors em1: Ethernet address: 0c:c4:7a:00:3b:d8 ehci1: <EHCI (generic) USB 2.0 controller> mem 0xdf823000-0xdf8233ff irq 23 at device 29.0 on pci0 usbus1: EHCI version 1.0 usbus1 on ehci1 pcib5: <ACPI PCI-PCI bridge> at device 30.0 on pci0 pci5: <ACPI PCI bus> on pcib5 vgapci0: <VGA-compatible display> mem 0xdd000000-0xddffffff,0xdf000000-0xdf003fff,0xde800000-0xdeffffff irq 23 at device 3.0 on pci5 isab0: <PCI-ISA bridge> at device 31.0 on pci0 isa0: <ISA bus> on isab0 ahci0: <Intel Cougar Point AHCI SATA controller> port 0xf070-0xf077,0xf060-0xf063,0xf050-0xf057,0xf040-0xf043,0xf000-0xf01f mem 0xdf822000-0xdf8227ff irq 19 at device 31.2 on pci0 ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported ahcich0: <AHCI channel> at channel 0 on ahci0 ahcich1: <AHCI channel> at channel 1 on ahci0 ahcich2: <AHCI channel> at channel 2 on ahci0 ahcich3: <AHCI channel> at channel 3 on ahci0 ahcich4: <AHCI channel> at channel 4 on ahci0 ahcich5: <AHCI channel> at channel 5 on ahci0 pci0: <serial bus, SMBus> at device 31.3 (no driver attached) acpi_button0: <Power Button> on acpi0 acpi_tz0: <Thermal Zone> on acpi0 acpi_tz1: <Thermal Zone> on acpi0 uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0 uart2: <16550 or compatible> port 0x3e8-0x3ef irq 10 on acpi0 ichwd0 on isa0 orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff on isa0 sc0: <System console> at flags 0x100 on isa0 sc0: VGA <16 virtual consoles, flags=0x300> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0 atkbd0: <AT Keyboard> irq 1 on atkbdc0 kbd0 at atkbd0 atkbd0: [GIANT-LOCKED] wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this. coretemp0: <CPU On-Die Thermal Sensors> on cpu0 est0: <Enhanced SpeedStep Frequency Control> on cpu0 p4tcc0: <CPU Frequency Thermal Control> on cpu0 coretemp1: <CPU On-Die Thermal Sensors> on cpu1 est1: <Enhanced SpeedStep Frequency Control> on cpu1 p4tcc1: <CPU Frequency Thermal Control> on cpu1 coretemp2: <CPU On-Die Thermal Sensors> on cpu2 est2: <Enhanced SpeedStep Frequency Control> on cpu2 p4tcc2: <CPU Frequency Thermal Control> on cpu2 coretemp3: <CPU On-Die Thermal Sensors> on cpu3 est3: <Enhanced SpeedStep Frequency Control> on cpu3 p4tcc3: <CPU Frequency Thermal Control> on cpu3 coretemp4: <CPU On-Die Thermal Sensors> on cpu4 est4: <Enhanced SpeedStep Frequency Control> on cpu4 p4tcc4: <CPU Frequency Thermal Control> on cpu4 coretemp5: <CPU On-Die Thermal Sensors> on cpu5 est5: <Enhanced SpeedStep Frequency Control> on cpu5 p4tcc5: <CPU Frequency Thermal Control> on cpu5 coretemp6: <CPU On-Die Thermal Sensors> on cpu6 est6: <Enhanced SpeedStep Frequency Control> on cpu6 p4tcc6: <CPU Frequency Thermal Control> on cpu6 coretemp7: <CPU On-Die Thermal Sensors> on cpu7 est7: <Enhanced SpeedStep Frequency Control> on cpu7 p4tcc7: <CPU Frequency Thermal Control> on cpu7 Timecounters tick every 1.000 msec ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled DUMMYNET 0xfffffe0009301dc0 with IPv6 initialized (100409) load_dn_sched dn_sched RR loaded load_dn_sched dn_sched WF2Q+ loaded load_dn_sched dn_sched FIFO loaded load_dn_sched dn_sched PRIO loaded load_dn_sched dn_sched QFQ loaded usbus0: 480Mbps High Speed USB v2.0 usbus1: 480Mbps High Speed USB v2.0 ugen0.1: <Intel> at usbus0 uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0 ugen1.1: <Intel> at usbus1 uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 uhub0: 2 ports with 2 removable, self powered uhub1: 2 ports with 2 removable, self powered ugen0.2: <vendor 0x8087> at usbus0 uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0 ugen1.2: <vendor 0x8087> at usbus1 uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1 uhub2: 6 ports with 6 removable, self powered uhub3: 6 ports with 6 removable, self powered ugen0.3: <Winbond Electronics Corp> at usbus0 ums0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0 ums0: 3 buttons and [Z] coordinates ID=0 ukbd0: <Winbond Electronics Corp Hermon USB hidmouse Device, class 0/0, rev 1.10/0.01, addr 3> on usbus0 kbd2 at ukbd0 ugen1.3: <SanDisk> at usbus1 umass0: <SanDisk Cruzer Blade, class 0/0, rev 2.00/1.00, addr 3> on usbus1 umass0: SCSI over Bulk-Only; quirks = 0x4100 umass0:8:0:-1: Attached to scbus8 ses0 at mps0 bus 0 scbus0 target 14 lun 0 ses0: <Intel RES2SV240 0d00> Fixed Enclosure Services SCSI-5 device ses0: Serial Number ses0: 600.000MB/s transfers ses0: Command Queueing enabled ses0: SCSI-3 ENC Device da0 at mps0 bus 0 scbus0 target 8 lun 0 da0: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device da0: Serial Number da0: 600.000MB/s transfers da0: Command Queueing enabled da0: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C) da0: quirks=0x8<4K> da1 at mps0 bus 0 scbus0 target 9 lun 0 da1: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device da1: Serial Number da1: 600.000MB/s transfers da1: Command Queueing enabled da1: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C) da1: quirks=0x8<4K> da2 at mps0 bus 0 scbus0 target 10 lun 0 da2: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device da2: Serial Number da2: 600.000MB/s transfers da2: Command Queueing enabled da2: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C) da2: quirks=0x8<4K> da3 at mps0 bus 0 scbus0 target 11 lun 0 da3: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device da3: Serial Number da3: 600.000MB/s transfers da3: Command Queueing enabled da3: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C) da3: quirks=0x8<4K> da4 at mps0 bus 0 scbus0 target 12 lun 0 da4: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device da4: Serial Number da4: 600.000MB/s transfers da4: Command Queueing enabled da4: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C) da4: quirks=0x8<4K> da5 at mps0 bus 0 scbus0 target 13 lun 0 da5: <ATA WDC WD30EFRX-68E 0A80> Fixed Direct Access SCSI-6 device da5: Serial Number da5: 600.000MB/s transfers da5: Command Queueing enabled da5: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C) da5: quirks=0x8<4K> da6 at mps0 bus 0 scbus0 target 22 lun 0 da6: <ATA WDC WD10JFCX-68N 1A01> Fixed Direct Access SCSI-6 device da6: Serial Number da6: 600.000MB/s transfers da6: Command Queueing enabled da6: 953869MB (1953525168 512 byte sectors: 255H 63S/T 121601C) da7 at umass-sim0 bus 0 scbus8 target 0 lun 0 da7: <SanDisk Cruzer Blade 1.03> Removable Direct Access SCSI-2 device da7: Serial Number da7: 40.000MB/s transfers da7: 15267MB (31266816 512 byte sectors: 255H 63S/T 1946C) da7: quirks=0x2<NO_6_BYTE> SMP: AP CPU #1 Launched! SMP: AP CPU #3 Launched! SMP: AP CPU #7 Launched! SMP: AP CPU #5 Launched! SMP: AP CPU #6 Launched! SMP: AP CPU #2 Launched! SMP: AP CPU #4 Launched! Timecounter "TSC-low" frequency 1650049344 Hz quality 1000 Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]... GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411) ZFS filesystem version: 5 ZFS storage pool version: features support (5000) GEOM_ELI: Device da1p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da0p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da2p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da3p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da4p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da5p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware GEOM_ELI: Device da6p1.eli created. GEOM_ELI: Encryption: AES-XTS 256 GEOM_ELI: Crypto: hardware
