I'm in the process of upgrading my current home freenas box. I should mention that my previous posts have said that my data isn't critical but my photography business has grown and it has now become critical, loosing a wedding is not an option.
My current box isn't an issue, it's just getting some ram, a new case, and rebuilt for a larger pool (10 drives instead of the 6 I have now). I'm also going to 4TB drives where I started with 2TB and I'll be going RAIDz3 now for the added protection.
My backup is the really important thing that concerns me. Currently my workflow looks like this:
Import to desktop or laptop computer, copy all files to NAS, Keep all RAW images on cards until delivery is complete. So I have a copy on my Laptop or Desktop (if I copied the wedding to the desktop I copy it to my laptop anyway as an added backup) I have the original camera cards (which is a real pain to leave them all full until I'm done editing) and the NAS. Backups everywhere and full SSDs on basically all of my machines. Not ideal. I'll note I have an added backup of my offsite crashplan but that has it's own issues I'm sure you're all aware of.
I've toyed with backing up to rotating hard drives, which is my highly preferred method. Problem is it's a real PITA. I don't have the budget or want to put hot swap drives in my NAS and the process with attaching backup drives and then removing them is a little bit of a headache to be honest. USB is unreliable. Finally, the data sets I need to backup are huge now, so a single drive isn't going to cut it. My photo library drive alone is over 3 TB and that only includes half of my work, none of the software backups or any of my other business document which if I were to look might be double that.
So I have two routes I'm thinking here. 8 TB SMR (archive drives I think they're advertised as). The plan then would be to insert one, have it copy the pool all the time. Take it out once a month or week or whatever (depending on how new the data is here I would probably change the times I swap it) Swap it with another, and put the new one back in for update and keep rolling. Again, not ideal and kind of a pain from my experience.
The second idea was something similar to this. https://forums.freenas.org/index.php?threads/portable-freenas-server.49800/
I'll have a bunch of 2TB drives when I'm done here and I don't need RAIDz3 for my backup pool. (I'd like to have 2 though...) The cost of what he has here is a little much, but I don't really need that much speed or the encrpytion. Anything that is sensitive gets encrypted on the client machines.
With this option, I think I'd bring this home once in a while, when I knew I had to new data to copy to it. You're probably wondering why I don't just put a new NAS at a friend's house. Honestly, I don't trust that they'll keep it running all the time, it won't get knocked around or beaten up. I prefer to maintain complete control of my data, so I'd be taking either of these options to work and leaving them there for the storage end of it. I also like fast write times.... which even with my fios just isn't gonna happen. Don't get me wrong I like my friends and my family, but I really like my clients to be happy, and there is always the legal issues as far as loosing documents goes!
So I guess this is a what would you do situation? How likely is it to be safe to keep either option "off" for the majority of the time? Being fair I could probably run the portable NAS box at work but network is a no go. I'll never be able to get network for it here.
Another option might be rotating 2TB's with changes back to another box here. Pop the drive in and ZFS send it in? Not really sure how that would work though. Backing up freenas has always felt a little weird to me where everything else is awesome, but it's something I need to deal with here soon because I don't really like trusting the cloud all on it's own.
Thanks for any insight.
