I have the results of some testing I have done. First I'll describe the files servers. These are creatively named freenas and freenas2.
freenas2 is my primary one.
Cisco UCS C240 M3S
FreeNAS 11.1-U4
Dual E5-2660 v2 CPU @ 2.20GHz
128G ECC RAM DDR3-1333
Chelsio T520-CR 10G-SR SFP+
t5nex0: <Chelsio T520-CR> mem 0xfb300000-0xfb37ffff,0xfa000000-0xfaffffff,0xfbb0
4000-0xfbb05fff irq 64 at device 0.4 numa-domain 1 on pci14
cxl0: <port 0> numa-domain 1 on t5nex0
cxl0: 16 txq, 8 rxq (NIC)
cxl1: <port 1> numa-domain 1 on t5nex0
cxl1: 16 txq, 8 rxq (NIC)
t5nex0: PCIe gen3 x8, 2 ports, 18 MSI-X interrupts, 51 eq, 17 iq
Drives controlled by LSI 9271-8i in JBOD mode
AVAGO MegaRAID SAS FreeBSD mrsas driver version: 06.712.04.00-fbsd
mrsas0: <AVAGO Thunderbolt SAS Controller> port 0xf000-0xf0ff mem 0xfbc60000-0xfbc63fff,0xfbc00000-0xfbc3ffff irq 56 at device 0.0 n
uma-domain 1 on pci13
mrsas0: Using MSI-X with 16 number of vectors
mrsas0: FW supports <16> MSIX vector,Online CPU 40 Current MSIX <16>
mrsas0: MSI-x interrupts setup success
17 x Cisco 1TB 7.2K SATA drives in internal drive bays
da0 at mrsas0 bus 1 scbus1 target 27 lun 0
da0: <ATA ST91000640NS CC03> Fixed Direct Access SPC-4 SCSI device
da0: 150.000MB/s transfers
da0: 953869MB (1953525168 512 byte sectors)
ZFS Pool where VMware virtual machines are stored shared via NFS v3
        RAIDZ2-I                                        ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/bd041ac6-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
            gptid/bdef2899-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
            gptid/bed51d90-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
            gptid/bfb76075-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
            gptid/c09c704a-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
            gptid/c1922b7c-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
            gptid/c276eb75-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
            gptid/c3724eeb-9e63-11e7-a091-e4c722848f30  ONLINE       0     0     0
          raidz2-1                                      ONLINE       0     0     0
            gptid/a1b7ef4b-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
            gptid/a2eb419f-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
            gptid/a41758d7-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
            gptid/a5444dfb-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
            gptid/a6dcd16f-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
            gptid/a80cd73c-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
            gptid/a94711a5-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
            gptid/aaa6631d-3c2a-11e8-978a-e4c722848f30  ONLINE       0     0     0
        logs
          gptid/6f76bc3b-5aee-11e8-8c41-e4c722848f30    ONLINE       0     0     0
        spares
          gptid/4abff125-23a2-11e8-a466-e4c722848f30    AVAIL
SLOG - Intel Optane 900P 280G
nvme0: <Generic NVMe Device> mem 0xdf010000-0xdf013fff irq 40 at device 0.0 numa-domain 0 on pci5
freenas is the secondary box that I don't use all that much. I may try and set up some automated replication to it at some point, but haven't been inspired to do so yet.
Cisco UCS C240 M3S
FreeNAS 11.1-U4
Dual E5-2620 CPU @ 2.00GHz
64G ECC RAM DDR3-1333
HP D2700 external enclosure with 25 SAS/SATA slots controlled by LSI 9207-8e. The D2700 has two controllers, and each one is connected to a port on the 9207-8e
mps0: <Avago Technologies (LSI) SAS2308> port 0x7000-0x70ff mem 0xdf140000-0xdf14ffff,0xdf100000-0xdf13ffff irq 32 at device 0.0 num
a-domain 0 on pci3
mps0: Firmware: 20.00.07.00, Driver: 21.02.00.00-fbsd
mps0: IOCCapabilities: 5a85c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,MSIXIndex,HostDisc>
ses0 at mps0 bus 0 scbus0 target 33 lun 0
ses0: <HP D2700 SAS AJ941A 0149> Fixed Enclosure Services SPC-3 SCSI device
ses0: 600.000MB/s transfers
ses0: Command Queueing enabled
ses0: SCSI-3 ENC Device
ses1 at mps0 bus 0 scbus0 target 59 lun 0
ses1: GEOM: da0: the secondary GPT header is not in the last LBA.
ses1: 600.000MB/s transfers
ses1: Command Queueing enabled
ses1: SCSI-3 ENC Device
25 x 300G 10k SAS drives in the D2700 look like this.
da5: <HP DG0300FAMWN HPDF> Fixed Direct Access SPC-3 SCSI device
da5: 600.000MB/s transfers
da5: Command Queueing enabled
da5: 286102MB (585937500 512 byte sectors)
        TEST2                                           ONLINE       0     0     0
            gptid/07379c8a-60ef-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/09d7ac93-60ef-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/0c7f06f4-60ef-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/0f28ba50-60ef-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/11cb5ce8-60ef-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/1478482b-60ef-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/a2e860a8-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/a59c35e2-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/aa159c4a-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/acd5a2e2-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/af81bbb2-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/b23b1e54-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
          raidz2-2                                      ONLINE       0     0     0
            gptid/f486e8de-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/f73b2f3f-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/f9eabce3-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/fc9f41a5-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/ff7e9906-60f5-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/029453a0-60f6-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
          raidz2-3                                      ONLINE       0     0     0
            gptid/084c70aa-60f6-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/0aff24d6-60f6-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/0dbd832b-60f6-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/10670ef6-60f6-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/1327e8dc-60f6-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
            gptid/15e5089e-60f6-11e8-bc93-f44e059f1a98  ONLINE       0     0     0
        spares
          gptid/1be4166c-60f6-11e8-bc93-f44e059f1a98    AVAIL
SLOG drive(s) controlled by LSI 9271-8i
bc63fff,0xfbc00000-0xfbc3ffff irq 56 at device 0.0 numa-domain 1 on pci13
mrsas0: FW supports <16> MSIX vector,Online CPU 24 Current MSIX <16>
SLOG using RAID1 with ST9146803SS drives (146G SAS 10K):
da50 at mrsas0 bus 0 scbus1 target 0 lun 0
da50: <LSI MR9271-8i 3.46> Fixed Direct Access SPC-3 SCSI device
da50: 150.000MB/s transfers
da50: 139236MB (285155328 512 byte sectors)
SLOG using RAID1 with ST9300653SS drives (300G SAS 15K):  *** This is RAID0 in tests with VM-UCS2 because I don't have enough 300G 15K SAS drives
da51 at mrsas0 bus 0 scbus1 target 1 lun 0
da51: <LSI MR9271-8i 3.46> Fixed Direct Access SPC-3 SCSI device
da51: 150.000MB/s transfers
da51: 285148MB (583983104 512 byte sectors)
I have 2 ESXi hosts that have enough local storage to hold the 3 VM's that normally have running all the time. Those a FreeBSD box (my mail server), Vcenter (small), and APC PC Network Shutdown (CentOS).
VM-DL360-G7
HP DL360 G7 - ESXi 6.0.0 - Dual X5672 CPU - 72GB RAM - P410i RAID - 4 x WDC WD7500BPKT RAID5
Mellanox Technologies MT26448 [ConnectX EN 10GigE , PCIe 2.0 5GT/s]
VM-UCS2
Cisco UCS C220 M3S - ESXi 6.5.0 - Dual E5-2670 CPU - 128G RAM - LSI 9266-8i RAID
UCS VIC P81E 10G NIC
Network switch is an HP S5820 (really an H3C OEM'd for HP). All connections between hosts and switch are 10G SR SFP using OM-3 fiber
Enough table setting, and on to the tests.
DL360-G7 client, freenas (secondary) server
No SLOG: 6.0G down, 342M up (peak) with ~= 250M avg up
Cisco 146G 10K SAS RAID1 SLOG: 6.0G down, 474M up (almost constant)
Cisco 300G 15K SAS RAID1 SLOG: 6.0G down, 730M up (almost constant)
DL360-G7 client, freenas2 (primary) server
6.6G down (peak) with ~= 5G avg, 4.9G up (peak) with ~= 4G average
VM-UCS2 client, freenas (secondary) server
No SLOG: 7.6G down (peak) 7.2G avg (sustained), 344M up (peak) ~= 212M avg (flucuates)
Cisco 146G 10K SAS RAID1 SLOG: 7.4G down (sustained), 637M (peak) up ~= 432M avg (sustained)
Cisco 300G 15K SAS RAID0 SLOG: 7.5G down (sustained), 847M (peak) up ~= 760M avg (sustained)
VM-UCS2 client, freenas2 (primary) server
8.3G down (peak) 7.8G avg (sustained), 4.2G up (peak) ~= 3G avg (sustained)
First off I have to say how impressed I am at the read performance FreeNAS is able to deliver even when using some older drives/controllers. Next, I was astonished by how much difference the SLOG made for NFS write performance. I know most people prefer iSCSI for backing VMware data stores, but I use NFS because I understand it better as a grumpy old Unix guy. I am mostly a network infrastructure person these days, so there isn't a huge motivation to learn iSCSI if I can get NFS to do what I need. I am going to try this again soon as I bought some used S3500 drives to use as an SLOG on the secondary host. I can certainly run some other tests if anybody would like. I know the storage Vmotion stuff isn't the most objective measure, but that is the thing that matters most to me so it seemed the ideal test.
One thing that puzzles me a little bit is how large the difference in write performance is between the 146G 10K drives and 300G 15K drives. How much is rotational speed, and how much is that the drive is larger? I certainly don't understand the architecture of ZFS well enough to answer that, but I am curious.
