icemule1
- Sep 27, 2022
I'm new to network storage, and I decided to go with TrueNAS Scale in case I want to run VMs or do other cool stuff from it someday. However, I only use it for file storage at the moment. I like that it's free and that ZFS prevents bitrot.
I've been using it for a few weeks now and today I tried giving it a static IP. After setting my IP (with a /24 as it originally was under DHCP), when I tried going to the new IP it made me create a new password for root, I figured that was some routine thing, but now I see is because somehow my server config got completely reset because now I can't even see my pools and I'm having my first "freak out" moment and don't want to accidentally enter a bad command that makes me lose my data for good. Any suggestions on how I can get my setup/config back, and why did this happen?
Here's my setup:
Here's my setup:
HP Z420 Workstation Motherboard 8x8GB Micron DDR3 ECC 1800MHz memory Intel Xeon E5 2660v2 10-core CPU 240GB Crucial SSD as boot drive 6x12TB WD Ultrastar DC HC520 hard drives set up as Z2 array (all connected to SATA ports on the motherboard) Radeon HD7770 1GB graphics card for console access
