SOLVED Pool Unhealty... Who do I believe?
kartracer
I have a pool that shows ONLINE (Unhealthy) RED X on the POOL Screen. However, the Dashboard shows ONLINE with a Green check mark. Who is right? I performed a Scrub against the pool and it showed 8 errors. I checked all connections and all are fine. Any thoughts would be greatly appreciated.
Samuel Tai
The scrub status is definitive.
kartracer
Thanks for your reply. Is there a way to find out what the errors are and from which disk? I have a MIRROR configuration.
Patrick M. Hausen
zpool status -v
kartracer
zpool status -v shows there are 8 files with permanent errors. I will try and delete/replace them and see what happens. Thanks.
Samuel Tai
Please show the output of the zpool status -v here. Some of those files may not be files; they may be metadata.
kartracer
They are mp4 and mkv files. I have already looked into couple of them and both get fatal error trying to play them mid way.
Samuel Tai
If any "files" look like this:
<name of file>:<hex code>
That's not the file that's corrupt, that file system metadata. Just replacing the file won't fix the metadata.
kartracer
Thank you for letting me know. I just checked again and none of the files have a :<hex code> following it. I have deleted the files and am now running another scrub to see if the results will be different.
Arwen
Note that ZFS was designed with redundant metadata by default:
rpool redundant_metadata all default
This means on a single disk pool, their are 2 copies of metadata, (and more copies of critical metadata). It can be changed, both as above and using "copies=2", (or 3).
On a simple 2 disk mirror pool, this would mean each disk has 2 copies of metadata, for a total of 4 copies.
ZFS designers took the approach that metadata is more critical that data. Meaning loss of a directory blocks taking out an entire huge file is unreasonable.
