compufreak
- Aug 27, 2018
Hi noob here, I will explain to the best of my ability what is happening
1. I have 3 FreeNas Servers running TrueNas Scale - TrueNAS-SCALE-22.12.3.3
2. Server 1 died, the BIOS is corrupt or something cant' figure out what is going on, keeps on rebooting
3, Server 3 was barely used, so I transferred all the disks in same order to Server 3
TrueNas boots up but now - I cannot for the life of me get my data on the disks....
It says that the Disks got data and it will be destroyed if I add it to a new Pool, If i add a new Pool / Import there is no pool in the selection box...
On the Storage Dashboard it says there are 3 Unassigned Disks " - The I click add to pool - 3.64 TiB HDD x 3 (MainData)
If add a new pool or Use Exisiting pool same ...
These are my disks Names - ANY Help will be appreciated, I need the data on those disks!
This disk is part of the exported pool 'MainData'. Adding this disk to a new or other existing pools will make 'MainData' unable to import. You will lose any and all data in 'MainData'. Please make sure you have backed up any sensitive data in 'MainData' before reusing/repurposing this disk.
Serial Disk Size Pool
