pool degraded on a *relatively* new drive
robot381
I set up a TrueNAS system around the second week of march, and i have JUST discovered that it has sent me a notification on 29th of March, that one of the drive is 'degraded because of persistent errors'.
Running zpool status -v results in:
root@truenas[~]# zpool status -v
  pool: FirstPool
 state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
        repaired.
  scan: scrub repaired 0B in 00:14:59 with 0 errors on Sat Apr 17 00:14:59 2021
        FirstPool                                       DEGRADED     0     0 0
          raidz1-0                                      DEGRADED     0     0 0
            gptid/85f8ce3a-7c14-11eb-a492-bc5ff4d6c187  ONLINE       0     0 0
            gptid/86500d99-7c14-11eb-a492-bc5ff4d6c187  ONLINE       0     0 0
            gptid/863a4c65-7c14-11eb-a492-bc5ff4d6c187  FAULTED      0     0 0  too many errors
errors: No known data errors
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:11 with 0 errors on Thu May  6 03:45:11 2021
          ada0p2    ONLINE       0     0     0
and then i ran: smartctl -a /dev/ada3
root@truenas[~]# smartctl -a /dev/ada3
smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.2-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZGY8SF4R
LU WWN Device Id: 5 000c50 0c89770d8
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri May  7 22:18:27 2021 KST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  591) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 613) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   076   064   044    Pre-fail  Always       -       41823680
  3 Spin_Up_Time            0x0003   095   095   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       9
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   079   060   045    Pre-fail  Always       -       74030916
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       1499 (62 172 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       11
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   065   059   040    Old_age   Always       -       35 (Min/Max 20/41)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       6
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       20
194 Temperature_Celsius     0x0022   035   041   000    Old_age   Always       -       35 (0 20 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       1498 (76 208 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       3528153642
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       447725359
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      1357         -
# 2  Extended offline    Completed without error       00%      1340         -
# 3  Short offline       Completed without error       00%      1189         -
# 4  Short offline       Completed without error       00%      1021         -
# 5  Short offline       Completed without error       00%       852         -
# 6  Short offline       Completed without error       00%       684         -
# 7  Extended offline    Completed without error       00%       620         -
# 8  Short offline       Completed without error       00%       412         -
# 9  Short offline       Completed without error       00%       244         -
#10  Short offline       Completed without error       00%        76         -
is there anything i can do to help this? or should i just get a replacement drive?
Thank you!!
Jailer
Not strong, but bad
Run a smart check on all your drives and post the output here. Complete hardware specs and TrueNAS version would be helpful as well.
marcevan
I bought 4 x 4TB Western Digital NAS drives and 3 were bad within first day. 2 of those were DOA. It happens.
You might consider looking at dmesg for CAM information... that may point you in a clearer direction if the disks are actually OK (which you should check with SMART)
