Plugins turn off and won't come back on
Paul9647
If I lose power and Frenas shuts down most of my plugins turn off. When I click on them to turn them back on they will not turn on. I usually have to delete and reinstall them. It can happen even if I do a reboot or shut down. This problem has been going for almost 2 years. Any ideas? Thank you.
Jailer
Not strong, but bad
Hardware specs please.
nojohnny101
Do you lose power to your NAS a lot? Why is that happening? Seems like you start at the root cause and go from there.
Paul9647
Paul9647
Anyone help me with this??
I just re downloaded a few of the plugins that did not work. I didn't uninstall the one that does not work, so now I have to of the same plugins 1 works one does not. I will restart the server and see if the one that works stops working.
Paul9647
It works after a shut down and pulling the cord. I have a error flashing that:
Alert System
WARNING: Aug. 19, 2018, 5:30 p.m. - smartd_daemon is not running.
Jailer
Not strong, but bad
You're not running enough memory to be running plugins, especially Plex.
Paul9647
Ok thanks. Add another 8gb? Do you think that's what the issue is? The cpu good enough still? I only stream 1 show at a time and dont have issues unless I lose electric power or sometimes after a restart from a update
Jailer
Not strong, but bad
Yes add another 8GB. It should bring some stability to your system but you still need to address the power outages with a UPS.
kdragon75
