MomSpaghetti
- Nov 16, 2017
I'm very new to FreeNAS. I've had my machine up and running for a few weeks, with Plex running on it. Now I'm having a problem, under available plugins it says "no entry has been found".
I've tried several suggestions on forums I've read, including setting nameserver 1 and 2 to 8.8.8.8 and 8.8.4.4.
From reading other forums, it seems to be a network problem. I logged into my router, and noticed that 192.168.1.174 says inactive, but that is the static IP I set for freenas. I can get the the webui for freenas using 192.168.1.174, so it's working, but not fully? When I setup the static IP, my router settings said that address was active. That is the only setting that I can see that is not the same as when everything was working fine.
I'm not sure where to go from here.
