Hello Everyone,
It's been awhile since I've posted anything. That's mainly because I haven't had any problems with my box that I haven't been able to figure out myself in quite awhile, until today. I updated to the latest 9.10 build and I got a warning message to upgrade the pools, which I did. I then noticed that all my plugins where off. They gave me the "some error occurred" message when I tried to start them. So I checked to see if the jails where running, which they where. I tried to ssh into them from the gui and from bitvise but I got nothing. I tried reverting to a previous boot environment but that didn't work. I decided to just rebuild everything since it seemed to only be a problem with the jails which are on a separate ssd. So I delete all my plugins and jails, detached the volume, and remade it. I rebooted after doing all this just incase and I got the below text in the console footer:
If I try to install a new plugin I get the following in the console:
I would appreciate any help with this. I not running many plugins. Basically plex, subsonic, transmission. and couple custom jails that can be rebuilt easily. But several friends and family members, as well as myself, use the subsonic server quite often so I would like to get it back up and running as soon as possible. My hardware specs are in my signature.
Thanks in advance.
Edit:
I rolled back to a previous boot environment and tried to update again. I have a critical system alert saying updated failed. I checked the update.failed file and got the following output.
Feb 11 15:41:07 freenas smbd: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:35 Err:-1 Errno:2 No such file or directory Feb 11 15:41:21 freenas collectd[3375]: geom_stats_open() failed, returned 16 Feb 11 15:41:21 freenas collectd[3375]: Initialization of plugin `disk' failed with status -1. Plugin will be unloaded. Feb 11 15:41:21 freenas collectd[3375]: Error: one or more plugin init callbacks failed. Feb 11 15:41:30 freenas uwsgi: [freeadmin.navtree:255] Failed to generate navtree for app freenasUI.vm: no such table: vm_vm
Feb 11 16:16:46 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:07 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:07 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:08 freenas smbd: dnssd_clientstub DNSServiceProcessResult called with DNSServiceRef with no ProcessReply function Feb 11 16:17:09 freenas uwsgi: [freeadmin.navtree:255] Failed to generate navtree for app freenasUI.vm: no such table: vm_vm Feb 11 16:17:18 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:28 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:30 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:31 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:33 freenas uwsgi: [freeadmin.navtree:255] Failed to generate navtree for app freenasUI.vm: no such table: vm_vm Feb 11 16:17:35 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:39 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:41 freenas uwsgi: [common.pipesubr:66] Popen()ing: zfs list -H -o mountpoint,name Feb 11 16:17:42 freenas uwsgi: [freeadmin.navtree:255] Failed to generate navtree for app freenasUI.vm: no such table: vm_vm Feb 11 16:20:12 freenas uwsgi: [common.pipesubr:66] Popen()ing: /sbin/ping -q -t 2 -o 10.0.0.101
Thanks in advance.
Edit:
There is no South database module 'south.db.sqlite3' for your database. Please either choose a supported database, check for SOUTH_DATABASE_ADAPTER settings, or remove South from INSTALLED_APPS.
