PlexMedia Server Won't Start with Static IP Jail
Vashan
Hey everyone,
I'm new to FreeNAS, so forgive me if this is something obvious.
I installed PlexMedia server and it works fine, but when I delete it, set Static IP's for my Jails
and reinstalled, it wont start. It says, "Some Error Occurred".
I cannot seem to find a Log of what it wrong, if you guys need this I understand and would ask
you where to find it.
Thanks very much in Advance,
Vashan
Vashan
I added a screenshot of my Plex Jail settings.
SweetAndLow
Sweet'NASty
Did you delete the plugin or just the jail? The log messages should be in the messages file(/var/log/messages).
Vashan
I deleted the plugin, which in turn removed the jail for me. I found the log, doesn't say much though;
May 5 18:07:15 plexmediaserver_1 newsyslog[62868]: logfile first created
May 5 18:07:15 plexmediaserver_1 syslogd: kernel boot file is /boot/kernel/kernel
SweetAndLow
Sweet'NASty
not in the jail but in freenas check the logs.
Jailer
Not strong, but bad
Hey everyone,
Vashan
System specs???
Vashan
Just for the heck of it, I uninstalled PMS again, set the Jails Config to DHCP. Now the service enables just fine, so must have something to do with the IP address...
Vashan
Well, I solved it another way. Reserved an IP on my router with the MAC Address from the plex server. Seems easier. Thank you for all the help everyone.
Randall_64
I had the same issue before. You have to stop the PMS plugin first. Then you can change the IP. Start the plugin again.
