dave_the_nerd
- Nov 16, 2013
So, I set up FreeNAS on some lowend gear (1037U motherboard, 4GB RAM, 3x2TB HDD in RAID-Z) and installed the PLEX plugin. Works great. Fed it my video library. Best thing ever.
BUT - if I have to reboot the NAS box for any reason, one or both of the following will happen.
1) The mapped storage (symlinks) from /volume/jails/plex_1/media/<foldername> -> /volume/sharedrive/<media foldername> will come unmounted. (Unlinked?) I can remount them in the web admin control panel under jails>plex_1>Storage. (Select mapping, click "mounted", save.)
2) One or both of directories I created in the jail (<foldername>, in the above) disappear, and I have to ssh in and mkdir again, or use the console in webadmin.
It's not every time. The last time I rebooted, both of the folders stayed put, but one of the symlinks didn't mount.
Once I set it up again, it'll work like a charm. Has this happened to anybody else? Any ideas? Particular log files I should look in? I know a "jail" is sort of a VM. Is it possible the VM is coming up either before or after some system daemon on the main OS that is relying on it to do the mapping correctly?
Thanks,
Dave
Thanks,
Dave
