PLEX Stopped working - FreeNAS-11.1-U7
cgaines78
FreeNAS-11.1-U7
My PLEX Media Server Plugin has stopped and will not restart. I tried to delete and reinstall and got an error below so uploaded file and still won't start!
I also updated FreeNAS to FreeNAS-11.1-U7 and still no response.
[MiddlewareError: Failed to download http://download.freenas.org/plugins/9/x64: HTTP Error 404: Not Found]
Not sure if it's related but my log at bottom of screen is constantly showing and just keeps adding lines of this:
Apr 23 09:36:11 GainesNAS kernel: arp: 8c:e2:da:f1:7d:63 attempts to modify permanent entry for 192.168.1.1 on epair0b
Apr 23 09:36:13 GainesNAS kernel: arp: 8c:e2:da:f1:7d:63 attempts to modify permanent entry for 192.168.1.1 on epair0b
My Plugin Repository is set to: http://download.freenas.org/plugins/9/x64/pbi-meta/pbi-repo.rpo
Chris Gaines
Malvern, AR
cgaines78@yahoo.com
D
dlavigne
Guest
Can you ping download.freenas.org from the FreeNAS shell?
Also, what is the output of ifconfig after a failed installation attempt?
Vincent Jansen
I am also having this same problem.
I can ping download.freenas.org from the terminal.
but I am not getting a list of available plugings.
My manualy installed plex server does not want to update.
Exception Value:[MiddlewareError: Failed to download http://download.freenas.org/plugins/9/x64: HTTP Error 404: Not Found]
Exception Location:./freenasUI/plugins/plugin.py in download, line 120
does anyone have a solution for this?
(I know im not running the latest version of freenas/truenas. Too afraid the update to the latest version will fail.)
ThreeDee
If your boot drive is an SSD and your hardware at least meets minimum requirements ..I'd upgrade to TrueNAS 12 and manually install plex in a 12.2 jail. I think you are going to half to to be able to run latest versions of Plex anyways
Vincent Jansen
All hardware requirements are met on my system, yet I keep reading about installation problems with truenas. Also, is the failing repository on older versions of freenas by design?
ThreeDee
The plethora of individuals that have installed TrueNAS successfully ... generally don't make posts about how easy it was to install (I'm one of those individuals).. I'd recommend a fresh install and then just reloading your saved config file.
It is a chore to maintain plugins .. so who knows .. it's just as easy to install from scratch and easier to maintain/keep up to date yourself .. and that's coming from a FreeNAS/TrueNAS noob
nojohnny101
I've had no problems installing plex on TrueNAS jail, multiple times. I'm currently on 12.2
Give it a try, I think you will find it easy enough and support is on here if you get stuck.
Vincent Jansen
Well i decided to update to Truenas.
I lost the previous plex install and jail. Installed the latest version of plex and all seemed fine.
unfortunately that success was short lived. I added mounts and then the plugin did not want to start anymore.
Error: [EFAULT] Stopped PlexTrueNAS due to VNET failure
So again no luck.
Vincent Jansen
Uninstalling the plugin and removing the jail.
Tried to install again and I gat the VNET failure during installation.
ThreeDee
start a new 12.2 jail and manually install Plex. Don't use the plugin .... easier to maintain/keep up to date
mkdir -p /user/local/etc/pkg/repos
ee /user/local/etc/pkg/repos/FreeBSD.conf
copy and paste the following
FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest" }
that will put you on latest repos instead of quarterly
Then you can run:
pkg update && pkg upgrade
pkg install plexmediaserver-plexpass
sysrc "plexmediaserver_plexpass_enable=YES"
To get quicker updates, you can run:
pkg install wget
pkg install ca_root_nss
pkg install perl5
fetch -o PMS_Updater.sh https://raw.githubusercontent.com/luluhoc/PMS_Updater/master/PMS_UpdaterPLEXPASS.sh
chmod 755 PMS_Updater.sh
./PMS_Updater.sh -vv -a
