Nvious1
- Jul 12, 2018
Do you have another machine that is maybe getting an address from your network from DHCP? Like maybe a windows PC that you can send an ipconfig /all. Not all home routers run their network subnets the same. Some run on 1.1 other run on 1.254. I need to better understand your local network setup to advise further. At the end of the day the defaultrouter="ip" is your "default gateway". On your vnet0| the /24 is equal to your subnet mask or 255.255.255.0 Here is an example of mine. If your mask are gateway are non-standard, you will need different values when hard-coding a static address.
Try to look at another machines configuration and map the components.
Ethernet adapter Ethernet 3:
Connection-specific DNS Suffix . :
IPv6 Address. . . . . . . . . . . : 2605:a601:20a1:8200:d9d9:de2d:a682:2e4e
Temporary IPv6 Address. . . . . . : 2605:a601:20a1:8200:999:413b:4c81:29b1
Link-local IPv6 Address . . . . . : fe80::d9d9:de2d:a682:2e4e%10
IPv4 Address. . . . . . . . . . . : 192.168.1.135
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : fe80::a9e:8ff:fee1:9998%10
192.168.1.1Try to look at another machines configuration and map the components.
